Posted: Tue Nov 27, 2001 3:02 am Post subject: |
No problems eating plugs on track here - though if they did I wouldn't care, just buy new ones - cheap enough! (in racing terms)
My only problem is the misfire, likely due to a bad coil pickup wire.
Joes924 Guest
Posted: Tue Feb 12, 2002 12:31 pm Post subject: |
Hey Vaughnn you hang out at that track your close to when speedvision is there for the differant classes of races your a test driver to or just an engineer.
Posted: Tue Feb 12, 2002 11:41 pm Post subject: |
You kidding me? The only time that track's been on Speedivision was when MotorWeak filmed a bit on the intro of the new Acura RSX there. Our racing does not get covered, ever, on TV. It's club racing. No market for that on TV.
As for the job - I am an engineer, not _just_ an engineer! I do my own test driving. I can't tell what car I'm currently working on, but the technology I'm currently working on is ESP - electronic stability control. Just like the Porsche Stability Management they put on the Carrera 4 - that's our Bosch ESP, just rebadged. Likewise, put it in an Olds, it becomes PCS (Precision Control System), or put it in a Toyota, it becomes TSC (Toyota Stability Control). My job is not just to evaluate it, but more importantly to tune the performance of the system (through in-car testing).
wdb Guest
Posted: Wed Feb 13, 2002 12:12 am Post subject: |
can you tell us the basics of what ESP does ,what does it adjust or change to improve stability. |
Posted: Wed Feb 13, 2002 12:46 am Post subject: |
Sure, though there is some info out there, better to get it from the horse's mouth, eh?
ESP can change the vehicle's dynamics in two ways. We can control engine output to reduce drive wheel slip, correcting an understeer or oversteer situation while on the throttle. That's easy enough to understand. The fun part is the brake interventions; we can actively build pressure (without the driver touching the brake pedal) and, through the ABS unit, apply that pressure to one or more wheels selectively to change the rate at which the car rotates.
For example, you turn in the wheel on ice, and the car doesn't rotate - just continues to plow, or understeer. We can grab the inside rear brake to force the car to rotate. That's an understeer intervention.
Now, of course, we're still limited by the tires - we can't change how fast the car can safely drive on any given surface, just recover from driver screwups due to inexperience. So we're not adding any performance to the vehicle. We're just making sure we use the most of what we got.
Likewise, if you whip a car back and forth on snow or pavement, the tail end will likely step out, and the car will slide or spin in oversteer. In this case, we can grab the outer front wheel to slow the rate of rotation, eliminating the oversteer condition, and regaining control for the driver. The car will no longer spin.
Does it slow you down? Yes, of course, it can. However, a properly tuned system (that's where I come in) will do so to a minimal degree, intervening only enough to sort the car out. A poorly tuned system will virtually stop the car by the end of a maneuver.
Typical maneuvers we use to evaluate the performance are single and double lane changes - emergency evasive maneuvers that, without intervention, will cause the car to slide or skid out of control. Speeds range from 30mph on glare ice to 65+mph on hi-mu (dry pavement).
The really fun part is driving in the snow, because you can really drift the cars around a lot.
Additional info, we add more sensors into the car to be able to tell what the car is doing, and what the driver wants the car to do. Through the wheel speed sensors, and a combination lateral accelerometer and yaw rate sensor we can tell what the car is doing. Through monitoring the brake light switch, accel pedal position, and steering angle (through a steering angle sensor mounted on the steering column) we can tell what the driver wants the car to do. If the two are sufficiently in disagreement, we can intervent and change the behaviour of the car.
HTH...
Joes924 Guest
Posted: Thu Feb 14, 2002 2:51 pm Post subject: |
You know that rev limeter sure does come in handy not to say I drive like a maniac.It has
a control inside that shuts down each cylinder to prevent over rev. in a way that doesnt foul plugs
Its my 924 ..and I love it ...and yes its getting faster/ 1979 924 Joe
[ This Message was edited by: Joes924 on 2002-02-20 18:55 ] |
