For stiff ones
dwak
PostPosted: Tue Feb 05, 2002 10:09 am    Post subject: Reply with quote
Trannies, that is. From todays general discussions.
Synthetic trans lube is what you need. I use Redline, but others have been happy with Mobil1, and Swepco
is a favorite for these cars.
vaughan@vaughanscott.com
'79 924 #77 ITA Blue/White
'82 931 Platinum Metallic
Plymouth, MI
http://www.vaughanscott.com
Webmeiste
carnut280
PostPosted: Tue Apr 16, 2002 1:38 pm    Post subject: Reply with quote
I too use Redline synthetic gear oil. it's the best. My father also uses redline in his 968 Cabriolet. Shifts REALLY smoothly
numbers
PostPosted: Thu Apr 18, 2002 7:26 am    Post subject: Reply with quote
I run Redline in my snailshell and am quite happy with it.
PostPosted: Fri Apr 19, 2002 4:20 am    Post subject: Reply with quote
I talked to Redline last night, they said you'd probably want the MTL-90 for the street (it's a 75W90 oil), but the 75W90NS for racing. I use the 75W90NS in my racecar. Will have to pick up some MTL-90 for the Turbo.
