AFRICA DEE
Joined: 16 May 2006 Posts: 48 Location: JOHANNESBURG, SOUTH AFRICA
Posted: Mon Jun 19, 2006 10:24 pm Post subject: DIFF BACKLASH PROBLEM |
I need some advice. I thought I had a problem with a noisy left rear CV, but it was strange because it only made a noise after a corner and the car was pointing straight again.
My car has the 5-speed dog-leg shift tranny, no lsd.
So the shaft and CV's came out and look fine, but the left rear short shaft that goes into the diff has about 3-5 mm forward play on the left but not on the right.
Is this the/a problem and what is the fix??
I have read a comment by Raceboy that there is a weak spline set up that holds a sattelite gear shaft in place but does not know if this is similar?
Thanks _________________ 1980 924 N/A Ex-931 Track car: My cash guzzler
2004 996 4S: My Weekend plaything
2012 VW POLO GT: My daily commuter |
