Srus569042 Guest
Posted: Fri Jan 25, 2002 11:27 am Post subject: |
My 1978 Porsche 924 came into contact with a tree at the back end, and it hit right smack in the middle. The bumper broke in half, and the whole back end is creased in a little. I have painted a new bumper, and it is ready to be put on, but I need to get the rest of the back end fixed. From where the rear key hole is for the hatch, all the way down, it's creased in, and I have pushed it out a little. With the bumper held up to where it is supposed to go, it looks funny with a big hole between where the bumper is, and where it's creased in. What does anyone recommend that I do? If a picture is needed, let me know. Thanks. |
Posted: Fri Jan 25, 2002 3:00 pm Post subject: |
a picture or two would be helpful then perhaps our resident body expert, Body Shop Rob, could give you a few tips. |
Posted: Sun Jan 27, 2002 10:03 am Post subject: |
here's what we're talking about. Any advice?
John H Guest
Posted: Mon Jan 28, 2002 2:29 pm Post subject: |
what does the tree look like.
prpbably pay to get the car put on a chassis machine and get the offending creases taken out of the lower section at least.
The upper section exposed to view should be able to be knocked back roughly into shape fair easily. The only hard part is the rail above the bumper and below the lights number plate. This is a real S*** to get dents out of.
John H Guest
Posted: Mon Jan 28, 2002 2:30 pm Post subject: |
probably pay to get the car put on a chassis machine and get the offending creases taken out of the lower section at least.
Posted: Sun Feb 03, 2002 11:01 pm Post subject: |
The damage won't be difficult to fix. Unless you have the experience and facilities to tackle this job, I would advise against it. It would appear as though it may need to be held down on a "frame straightner" in order to pull out some of the damage in the bumper area. Hammering from the inside of the spare tire area won't cut it.
The rest of the damage can be pulled out with a uni-spotter and a slide hammer, then finished using conventional autobody methods.
Joes924 Guest
Posted: Sun Feb 17, 2002 6:49 am Post subject: |
Id go ahead and give it my very best shot
best shot...
Posted: Sun Feb 17, 2002 7:44 am Post subject: |
I am sure a good crack filler could mix up a batch of Dura bond that would fill those dents in nicely.
wdb Guest
Posted: Sun Feb 17, 2002 8:01 am Post subject: |
The way I see it is ,the more information you have,the more likely you are to make the right discission. take it to 4 or 5 body shops,get estimates, and then discide wether to repair it your self, have shop do it, or buy another car.or if you know a welder,dare I say it, ... amputate the damaged area and weld a tail back on. while your in there,you could customize a little
http://www.asarus.com/ressources/924_break.jpg |
Joes924 Guest
Posted: Sun Feb 17, 2002 11:05 am Post subject: |
get a torch and start cutting find the ass
of another well and piece that sucker together body fill with filler sand sweat concentrate and doit..
Joes924 Guest
Posted: Wed Feb 20, 2002 6:15 pm Post subject: |
Oh lord god jesus I give you all my praise ...help this person see what he has done by hitting this tree and ... give me grace to do this project... what happend to the tree did you put a bandage on it you should you know
Vince Ponz Guest
Posted: Fri Feb 22, 2002 12:17 am Post subject: |
Email PHOLIAT@aol.com because he is chopping up a 931 and could or would sell you the rear.
AznDrgn Guest
Posted: Fri Feb 22, 2002 12:33 am Post subject: |
I highly reccomend no trying to weld on a new back end. There is a special method to doing it so that in the event the car is hit it will crash properly and not kill you. If you intend on welding leave it to a professional. |
MixMaster K Guest
Posted: Sun Feb 24, 2002 6:07 am Post subject: |
I have a 78 with a decent back end on it. I need to get rid of this car as I am moving in the next few weeks. Email me if interested. If you're interested in it as a parts car, then I could use the passenger fender for my '79. Engine has good compression, however, I have taken the camshaft and cam followers out and replaced it to my '79.
The lower section of the car will definitly have to be replaced. It is a structural part of the car. However before you can do this the car will have to be put on a frame rack and pulled back to spec. Tolerances for unibody cars are 0-3mm.
[ This Message was edited by: MixMaster K on 2002-02-24 07:14 ] |
Joes924 Guest
Posted: Mon Feb 25, 2002 1:54 pm Post subject: |
If it was me and i was short on dough
id pull it out as much as i can then fill it
your tail lights didnt even break
[ This Message was edited by: Joes924 on 2002-02-26 12:07 ] |
