gautney
Joined: 11 Oct 2005 Posts: 19 Location: Salt Lake City, Utah
Posted: Mon Mar 20, 2006 4:08 am Post subject: Coolant leak |
I have noticed that coolant is leaking inside the car. It is all over the passanger side floor, does anyone have any idea what would cause this? Any comments would be helpful.
Thanks! _________________ 1998 Boxster
1979 924
1962 356b |
Posted: Mon Mar 20, 2006 4:43 am Post subject: |
Not great news. I may have to go have a beer on your behalf...
Heater core problem - could be (a) a broken connection at the firewall or if you're lucky (b) a hose at the firewall in the engine compartment came loose, plus there's an opening that allows coolant to spray back into the passenger compartment. More likely (a) or a bad heater core which means some extensive work under the dash.
Look here - http://www.924board.org/viewtopic.php?t=13541 _________________ "..it's made in Germany. You know the Germans always make good stuff."
