1mm skimmed off the top of the engine block
sarbirus
PostPosted: Mon Mar 24, 2008 8:32 am    Post subject: 1mm skimmed off the top of the engine block Reply with quote
Years ago, someone told me that a 924 makes extra power if the compression is raised a little and taking 1mm from the top of the block was about right for a euro 924 na engine.. is this true?
Sarbirus
England
92 964C2 - Thinking about converting to widebody
89 944 Turbo - Modified by JMG/9XX 400 BHP
83 944 Lux - staying standard for now
83 924 Lux - 9XX head - transformed performance!
81 924 turbo - staying standard... probably
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
PostPosted: Mon Mar 24, 2008 9:36 am    Post subject: Reply with quote
Yes, but it will effect your valve timing.
sarbirus
PostPosted: Mon Mar 24, 2008 10:01 am    Post subject: Reply with quote
That makes sense, so I would need a adjustable cam pulley, ok.
So what is the standard compression ratio of a euro engine (XJ) and what would it rise up to by taking 1mm off of the block?
Has anyone done this? what did they find it did to the power delivery of the car?
Sarbirus
England
PostPosted: Mon Mar 24, 2008 10:29 am    Post subject: Reply with quote
The search button found this:
http://www.924board.org/viewtopic.php?t=21097&highlight=compression+ratio
endwrench
PostPosted: Mon Mar 24, 2008 11:41 am    Post subject: Reply with quote
1mm should give you around 10.1:1 with euro 9.3:1 pistons. it will retard your cam about 1.3°.
Todd
Martijnus
PostPosted: Tue Mar 25, 2008 2:08 am    Post subject: Reply with quote
I've skimmed a mm off too, haven't put the engine back together, but my calculations gave me about 10:1 compression ratio... 2mm would give 11:1 but someone calculated this again a while ago and that differed from my calculations.
So I'm not sure about it... but 10:1 or 1mm would be safe... and valve timing changes indeed... that is quite easy to calculate too.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
