jesse wall
Posted: Sat Feb 25, 2006 1:44 pm Post subject: 944s in 924s ? |
anybody tried putting a 944s engine in a 924s ? problems ? thanks _________________ jesse wall 'new driver' , 87 924s |
Llamaguy
Posted: Sun Feb 26, 2006 5:32 pm Post subject: |
it has been done, should be an almost straight bolt in plus ECU. Might have trouble with the Drive shaft, but you'd need almost the entire car to do it anyways so you would just swap trannies anyways. _________________ 1987 924S Guards Red
1997 Suzuki Tl1000 Supersport |
Lemming
Joined: 14 Apr 2004 Posts: 77 Location: Birmingham, AL
Posted: Fri Mar 24, 2006 1:05 pm Post subject: |
Jesse,
I dropped a 968 engine in my 924S. The only issue was the brake booster which I had to move up about 2 cm to clear the intake manifold. Not sure if this will be a problem with an S motor. Other than that, it was a direct bolt in
The writeup can be found at http://forums.rennlist.com/rennforums/showthread.php?t=221429&highlight=924s3+update
Here's what she runs like, the video is from Road Atlanta a few weeks ago Click here _________________ Tim
'95 968 (White/Cashmere)
'88 924S? (sleeper |
Posted: Fri Mar 24, 2006 2:31 pm Post subject: |
Great job, I've got to try that some day!
Is the 968 motor an interference motor? Are you running the belt covers? _________________ White 87 924S "Ghost"
Lemming
Posted: Sat Mar 25, 2006 2:21 am Post subject: |
Yep, same basic engine as teh 944, only 3L and with variocam.
I don't run the belt covers, but do run the undertray. _________________ Tim
