Now what?
BillA
PostPosted: Wed Jan 18, 2006 12:16 pm    Post subject: Now what? Reply with quote
Well, here is my problem I purchased these pistons from PAECO a few years back, my intent was to use an NA head with this setup. I was told they were rated for 11:1 CR It is a 931 block bored out .040 over, crank and rods are 931 as well. After my machinist finished boring, balancing and a couple of other things he called me and gave me bad news. With this current setup I'd be lucky to get 5 possibly 6:1 CR. Don't know if shaving the deck would help at this point any suggestions would help. Oh, I called PAECO and did not get any satisfaction. I also called VENOLIA, they made these pistons, gave him the part number off the piston and all they could tell me was they stopped carrying that piston back in 91. Any ideas would help. Thanks for the help and advice for loading pictures on the forum!
Khal
PostPosted: Wed Jan 18, 2006 12:42 pm    Post subject: Reply with quote
The 931 block, crank and rods are the same as the 924, as I unsderstand it. So that will make no difference.
The 931 pistons are different, they are dished and sit flush with the deck of the block at TDC. The 931 head has combustion chamber recesses in it.
This is different from the 924 head, which is basically flat with a small recess for the valves (if you've got a 924 head, you've probably noticed that).
The 924 pistons are recessed in the bore, forming the combustion chamber in the bore.
So, shaving the deck of the block will raise the compression. But you can only shave it a certain amount (about 0.5mm or 0.020 in., I've read), otherwise valves meet pistons...
Though the compression gain is only 9.6:1 over standard 9.3:1, apparently.
BTW, those pistons look all but identical to the original ones to me...
EDIT: No, sorry. Yours look like they have a much larger/deeper bowl in them
'80 924 Turbo
PostPosted: Wed Jan 18, 2006 12:52 pm    Post subject: Reply with quote
was the compression ratio calculated using a 924 or a 931 head?
My924gtc
PostPosted: Wed Jan 18, 2006 1:47 pm    Post subject: Reply with quote
Gee our first real PAECO feedback and low and behold there is a problem, a major problem. Maybe now people on this board will think twice before they recommend them to our members without having personal experience with them. Interesting that they use Venolia for their pistons considering that they are on the opposite side of the country. What nobody forges pistons in Alabama? Probably not. Jacks of all trades, masters of none.
Anyway, yea the dish in those pistons is way off. Here are Euro 9.3:1 and US 8.5:1 stock slugs
As you can see the dish is the only thing that changes and that the Euro's have nearly no dish. At 11:1 you would have even less.
Just out of curiosity...why the 924 head?
Khal
PostPosted: Wed Jan 18, 2006 2:09 pm    Post subject: Reply with quote
My924gtc wrote:
Anyway, yea the dish in those pistons is way off. Here are Euro 9.3:1 and US 8.5:1 stock slugs...
Ah, yes, I forgot the U.S. cars have a lower compression!
I agree that 11:1 you'd have flat-tops or even domed pistons! Euro, U.S. or otherwise!
Indeed, why?
Although if I had to guess, I'd say it's because saves BillA having to make a new intake and exhaust manifold..? And buy new pistons (even though it looks like he's gonna have to anyway...)
'80 924 Turbo
moone924
PostPosted: Wed Jan 18, 2006 2:52 pm    Post subject: Reply with quote
without mod he could use the turbo intake manifold.
Ryan Moone
New philosophy : one car project at a time.
Khal
PostPosted: Wed Jan 18, 2006 2:54 pm    Post subject: Reply with quote
Assuming he's using the Turbo head, right?
Are the injectors the same on the NA and the Turbo? I though they might be different..? There's probably a bit of a fiddle in that...
Are there no other problems hooking up the NA CIS to the Turbo intake manifold?
'80 924 Turbo
moone924
PostPosted: Wed Jan 18, 2006 3:00 pm    Post subject: Reply with quote
the injectors are in the head on the NA head, and without walking to my shop I can't tell you where the injectors are on the turbo head, but wherever they are I'm sure someone could use the NA injectors in the turbo injectors place.
edit..... in the head or in the intake manifold. Also know it's possible to use the turbo intake manifold on a NA head with some grinding and such, so it should be the same the other way around.
Ryan Moone
Kenodog
PostPosted: Wed Jan 18, 2006 3:58 pm    Post subject: Reply with quote
Just out of curiosity what is the measurement between the wristpin and the top of the new slug ? Also measure the stock na slug.Then all you have to do is cc the dishes in both to figure out the cr exactly.I assume you're using stock 924 rods.With these engines I find it hard to believe you could even get an 11:1 cr unless you recessed the valves somehow.Someone here did the math once and figured that you would have to shave 0.050" from the block to raise cr by .5 .This means adding almost .170" to the top of an already tall Eurospec piston! Way too close for my comfort.
That being said you may find taller rods.There seems to be a bit of mix and match between Vdub rods and ours,you may be able to get GTI or Rabbit rods that will do the trick for you.You should be able to find a thread in the archives here.There is also the possibility you can use the 87mm Vdub flat tops instead?Shaving any substatial amount from either the block or head is definitly not an option.
I've dealt with Paeco on a few things and have never had a problem,in fact I found them to be really good to deal with.And hey let's be realistic,I don't know of ANY company selling ANYTHING that would do an exchange over the phone on a product bought a couple of YEARS ago.
caveat emptor
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Khal
PostPosted: Wed Jan 18, 2006 4:23 pm    Post subject: Reply with quote
moone924 wrote:
the injectors are in the head on the NA...
Oh yeah, they're in the head on my car, too. How'bout that? I never ever noticed... coulda sworn they were in the intake...
Seems you're right.
From this thread...
Raceboy wrote:
I did put 931 intake onto my wifes white NA, but it required modifying manifold (bigger mounting holes) and A LOT of port matcing to 924 NA head.
This 931 head swap is sounding better all the time. Why doesn't everyone do this?
Sorry, I'm hijacking the thread! Back to the point...
'80 924 Turbo
PostPosted: Wed Jan 18, 2006 6:28 pm    Post subject: Reply with quote
if you have a machined NA head:
1. get a hudge turbo and make 300hp+ with that CR(maby get it to 7:1)
or
2. get new pistons...to raise your CR, those are turbo pistons as i see it...they were designed for low CR...
Min
PostPosted: Wed Jan 18, 2006 9:06 pm    Post subject: Reply with quote
http://kb-silvolite.com/calc.php?action=comp
Get the data, plug it in, play with the stuff you can change(like deck height and gasket thickness) until you get a acceptable cr.
Min
-nick
PostPosted: Thu Jan 19, 2006 4:49 am    Post subject: Reply with quote
How did your machinist determine the compression ratio? Dish volume doesn't mean anything without knowing the compression height of the piston (distance of the wrist pin to the crown). I think this is what Kenodog is alluding to. It's difficult to tell, but it appears that your pistons sit up a little higher in the block than stock. Hard to say without measuring though.
My924gtc- have you had bad experiences with Paeco? Sounds like some sort of grudge? I believe that they use only Wiseco pistons now, not sure about a decade ago. Either way, Venolia has a pretty solid reputation as far as I know. I'm not sure what proximity has to do with picking a piston manufacturer?
I called up Paeco a couple years ago and got a hold of a random tech guy who was surprisingly knowledgeable. Anyone who can quote piston-to-cylinder wall clearances off the top of his head for a car that isn't necessarily their specialty makes me listen. Of course, he tried to push one of their prepared long blocks a bit, but not down my throat. My impresion is that they test their builds pretty well before marketing them. Something few "tuners" seem to do.
This is getting off-topic. Let us know how the CR numbers were calculated.
nick
My924gtc
PostPosted: Thu Jan 19, 2006 5:27 am    Post subject: Reply with quote
-nick wrote:
My924gtc- have you had bad experiences with Paeco? Sounds like some sort of grudge? I believe that they use only Wiseco pistons now, not sure about a decade ago. Either way, Venolia has a pretty solid reputation as far as I know. I'm not sure what proximity has to do with picking a piston manufacturer? nick
Proximity has everything to do with solving problems when they arise and getting accurate information conveyed. I am just spoiled because I can throw a stone and hit any kind of auto manufacturer you can think of, including pistons.
As far as a grudge is concerned I have only information passed on by others that have dealt with them and not necessarily 924/931 related. I have spoken to them in the past and was not satisfied at all with the discussions and decided not to get anythinig from them. Regardless, I would never buy anything from a middleman now when I can go straight for the throat, but that's just me.
I will say this...since I have thousands of $, and over a year of my life, tied up in creating engine mods and induction systems for the 924/931 that will soon be put to market, I will not endorse anyone like Paeco. What can I say I'm a capitalist.
MJ
'81 924 2.0L T
'82 924 2.3L SC/EFI <---online fall '06
Sponsor of the 944 Cup and Super Cup
Sponsor of the "2006 Battle in the Badlands"
