how to find fuel leak?
timstar92404
PostPosted: Thu Nov 10, 2005 7:07 pm    Post subject: how to find fuel leak? Reply with quote
I don't know if I have a fuel leak but i'm just wondering due to my fume problem giving me headaches. One of my parent's friends today found out that her car is leaking gas and the mechanic told her she was luck her car didn't blow up. She was also complaining about getting dizzy and sick while driving, my mom told me this so it kinof made me paranoid about my car.
I don't smell gasoline inside the car unless the car doesn't start and I keep on cranking it but thats the smell of the gas coming out the exhaust and the windows are open.
someon arlready said to check the gas hose in teh trunk, I've never seen a gas hose in the trunk area but I'll look.
how do you tell if a gas hose is leaking, gas evaporates so you can't see wet spots.
78 924 sold.
85.5 944
timstar92404
PostPosted: Thu Nov 10, 2005 7:20 pm    Post subject: Reply with quote
oh yeah I have another question.
I'm going to go order some parts from weissach (sell porsche parts) and I'm wondering what that spongy seal that seals inside the shifter are ais called? is it just a one piece spongy seal or what? the one I have leaks air. when the car was jacked up I saw the spong seal underneat the car also.
anyone also knwo how you remove this and replace it with a new one to make it airtight?
78 924 sold.
85.5 944
Chrenan
PostPosted: Fri Nov 11, 2005 1:21 am    Post subject: Reply with quote
Put your car safely up on four jack stands with blocks under all four wheels just in case. Jumper the fuel pump relay so the pump runs continuously while the engine is NOT running. Get a light and lie under your car and follow the fuel lines from the tank to the engine compartment and back. Easy as that.
