924guy
Posted: Thu Mar 10, 2005 7:09 am Post subject: nuts and bolts..aaargh.. |
so im in need of new exhaust system studs, basically all of them, manifold to head, turbo exhaust flange, wastegate, etc..and ofcourse the matching nuts.
so far ive sat with two different, very patient parts counter people in an attemp to match them up with the stores inventory..havent been able to find even one..either their the right length and wrong width, or wrong length and right width..and forget about the nuts..
but i thought id try one last time before i bite the bullet and order them through porsche (whom i know will empty my wallet) ..
does anyone have an alternate source for this hardware? i need someone who either can cross reference the parts, and find me the proper replacements, or has some experience in porsche hardware substitutes..you know, some who wont just listen to what i need and say "duh, i don know.."
any help on this would be appreciated, there has to be replacement equivelents out there someplace, doesnt there?? i mean theyre just nuts and bolts after all..i really want to avoid paying the porsche markup on these if i can avoid it..but i also need these to finish up, and im getting frustrated.. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
CMXXXI
Posted: Thu Mar 10, 2005 9:19 am Post subject: |
I don't think there is anything "special" about the nuts and bolt, and I would think that any supply house that carries metric hardware should be able to fill the bill. Here's a list of what is needed, stud-wise [ thread dia x stud length (qty) ]:
Manifold to J-tube.................10x35 (2)
Turbo to exhaust pipe...........10x28 (4)
Turbo to exhaust manifold.....10x25 (2)
Turbo oil bracket......................8x35 (2)
Wastegate to J-tube (bottom)..8x32 (4)
Intake manifold........................8x30 (4)
Wastegate to exhaust (side)...8x25 (4)
Exhaust manifold.....................8x25 (8)
10mm threads are 1.5 pitch
8mm threads are 1.25 pitch
There are a lot of places where you can buy hardware on the net, but the problem you may find is either a minimum quantity, or minimum $$ order. Even Home Depot carries the stuff, but their markup rivals what a dealership might charge. Have you tried other auto dealerships? Even US cars are more metric than SAE now-a-days. _________________ '79 Eurospec 931 |
jpab924
Joined: 03 Nov 2002 Posts: 1538 Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
Posted: Thu Mar 10, 2005 3:30 pm Post subject: |
www.paragon-products.com
I`d give them a try. Even though they don`t have them listed on their website, give them a call and they may be able to help you out.
Another place to try....sears hardware....they have bins with metric studs in the hardware dept. I`ve found some odds and ends there. |
jpab924
Posted: Thu Mar 10, 2005 3:40 pm Post subject: |
quick search on pelican yielded these results:
Catalog Parts Search: See 267+ more results
Description Part Number Category More Info
Cylinder Head Exhaust Stud (exhaust, M8 X 20mm, 12 required, sold per each), 911 (1974-77)
K-062-006-02 Cylinder Head Intake and Exhaust Studs
Cylinder Head Exhaust Stud (exhaust, M8 X 30mm, 12 required, sold per each), 911 Turbo (1986-89)
K-062-239-02 Cylinder Head Intake and Exhaust Studs
Exhaust Port Stud, 8 X 40 mm, 320i/is (1976-83), Each
BW-07-12-9-908-134 Exhaust Studs
Exhaust Manifold Stud, M8 X 30mm, 8 Per Car, Cylinder Head to Exhaust Manifold, 924S (1987-88 ), 944 (02/85-89), 944 Turbo (1986-89), Each
K-062-044-02 Exhaust Manifold Studs
Exhaust Manifold Stud, Cylinder Head to Exhaust Manifold, 12 Per Car, 944S (1987-88 ), 944S2 (1989-91), 968 (1992-95), Each
K-062-139-02 Exhaust Manifold Studs
I didn`t put the smilies in above.....don`t know why they are in there....!
Posted: Thu Mar 10, 2005 4:05 pm Post subject: |
Hey jpab
924guy
midas had them for me. I took the mani in & had a few
broken studs pulled & replaced. At least now you knoew the sizes
try a good auto parts place _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
924guy
Posted: Fri Mar 11, 2005 1:36 am Post subject: |
thanks for the replies guys.. i took the above list, and added the nuts to it:
Manifold to J-tube.................m10 hex locking 14mm head 1.5 pitch (2)
Turbo to exhaust pipe...........m10 hex locking 15mm head 1.5 pitch (4)
Turbo to exhaust manifold.....m10 hex locking 13mm head 1.5 pitch (2)
Turbo oil bracket......................m8 hex locking 13mm head 1.25 pitch (2)
Wastegate to J-tube (bottom)..m8 hex locking 13mm head 1.25 pitch (4)
Intake manifold........................m8 hex locking 12mm head 1.25 pitch (4)
Wastegate to exhaust (side)... m8 hex locking 13mm head 1.25 pitch (4)
Exhaust manifold.....................m8 hex locking 12mm head 1.25 pitch (
i "think " i got the head sizes right, but im not positive..with all nuts in a jumble here, some of it was guess work, but they should be close. and i emailed a metric hardware place i found on the web with the list, and am hoping for a prompt reply.. well see what happens..napa and discount auto parts dont carry the proper lengths, or at least the parts people i sat with couldnt find them in their books..but maybe this is some small progress.. but if anyone sees errors in my list, please let me know.. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
CMXXXI
Posted: Fri Mar 11, 2005 4:22 am Post subject: |
jpab - The smileys are there because you inadvertently typed in an emoticon. An '8' followed by a closing parenthesis ')' is the symbol for the "sunglass smiley", so '88' followed by the paren displays as an '8smiley'. The way to prevent this is to click the check box below the editing area that says "Disable smileys in this post" when you compose a post, or put a space between the 8 and the ')'
924 guy, I don't know about the 8mm hardware for sure, I've run across 11, 12 & 13 mm cross flats nuts, but I have to question the 10mm stuff. I do know that the turbo-to-exhaust pipe nuts are 10x1.5, with 15mm across flats. The OEM ones are a very odd and specialized nut. "Standard" 10mm nuts are larger across flats, and if you try and use them on the exhaust pipe, the corners of the nut will interfere with the welds on the pipe flange.
click for larger image
In the photo above (all 10 x 1.5mm), the OEM one is on the left, one from a Mercedes in the center, and one from a local auto parts store on the right. I'm not sure I've ever encountered a 10mm threaded nut smaller than 15mm cross flats. Anything less and there isn't much material to make up the side walls. _________________ '79 Eurospec 931 |
Posted: Fri Mar 11, 2005 2:34 pm Post subject: |
I don't know if the NA hw would be the same as the Turbo, but I bought extra studs and nuts when I redid my HG a month or so back...if your interested, I can take pix of what I have, and if they'll work, you're welcome to them. I even have a handful of the copper lock nuts left...I won't be home until next Thursday, but let me know... _________________ erstwhile owner of just about every 924 variant ever made |
jpab924
Posted: Sat Mar 12, 2005 12:55 pm Post subject: |
| CMXXXI wrote: | jpab - The smileys are there because you inadvertently typed in an emoticon. An '8' followed by a closing parenthesis ')' is the symbol for the "sunglass smiley", so '88' followed by the paren displays as an '8smiley'. The way to prevent this is to click the check box below the editing area that says "Disable smileys in this post" when you compose a post, or put a space between the 8 and the ')'
Aha! thanks for pointing out the errors in my ways...post is now
fixed
924 guy, I got my nuts from paragon...I still have a few bags left over but will need them for any future re-build. I called them to get what I needed which was not listed on their product page. Nice people to deal with. |
CMXXXI
Posted: Sun Mar 13, 2005 12:38 am Post subject: |
| ideola wrote: | | I don't know if the NA hw would be the same as the Turbo... |
There are some differences I saw in PET, there may be others.
Intake manifold:
NA=8x1.25x30 (4)
931 (correction to my earlier post)=8x1.25x35 (2) 8x1.25x30 (2)
Exhaust manifold:
NA=8x1.25x30 (8)
931=8x1.25x25 (8)
And, an addition to the list for anyone adding this trivia to their personal "cheat sheet", the studs for the valve cover are 6x1.25x25mm, and the studs that the cam bearing caps fit on are 8x1.25x56mm _________________ '79 Eurospec 931 |
924guy
Posted: Wed Mar 16, 2005 2:51 am Post subject: |
i went ahead and sent a list over to paragon, and theyre getting prices for me..but they say most have to come from germany and it may take awhile..but at least im making progress..
anyone ever compare paragon prices to the dealer? curious if theyll charge me more, less, or around the same.. rather order from paragon if possible..last time i ordered from my "local" dealer, i wasnt really impressed by them..other dealers ive dealt with were much better..but thats not an option at the moment.. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
CMXXXI
Posted: Wed Mar 16, 2005 4:13 am Post subject: |
...Just as a general comment...
I find it hard to believe that these metric fasteners can't be obtained locally...the question is "where" though. I've had a hard time finding nuts and bolts too, but managed to scrape them together from various auto parts places. Yes, the studs are an "odd" item, but with the number of vehicles out there that use metric stuff, you'd think it wouldn't be that hard. I mean, really, surly the Honda or Nissan or Toyota places don't have to send away to Japan for simple nuts and bolts...
Here in my corner of the South there is a company called "Hudson's" that does buyouts from insurance companies - flood, fire, bankruptcy, etc - and a year ago Christmas one of the Hudsons stores had the stock from a hardware place, to include aisle upon aisle of fasteners of all sizes and description. I loaded up with 6, 8, 10 & 12 mm nuts and bolts, and even some studs that I found. For pennies on the dollar it was a real find. What this tells me is that there ARE places around that carry the stuff (in bulk no less), it is just a matter of finding them. _________________ '79 Eurospec 931 |
924guy
Posted: Wed Mar 16, 2005 4:37 am Post subject: |
| CMXXXI wrote: | ...Just as a general comment...
Here in my corner of the South there is a company called "Hudson's" that does buyouts from insurance companies - flood, fire, bankruptcy, etc - and a year ago Christmas one of the Hudsons stores had the stock from a hardware place, to include aisle upon aisle of fasteners of all sizes and description. I loaded up with 6, 8, 10 & 12 mm nuts and bolts, and even some studs that I found. For pennies on the dollar it was a real find. What this tells me is that there ARE places around that carry the stuff (in bulk no less), it is just a matter of finding them. |
I know exactly what your saying..i didnt put much priority on the hardware, because i figured that would be the easiest parts to find..no such luck though, ive spent day looking (literally) locally, and lots of time online searching.. no luck, or limited luck, and it wasnt worth the shipping for one or two studs..... and its hard to believe... guess porsche has the nuts and bolts market locked up.... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
john h
Posted: Wed Mar 16, 2005 2:27 pm Post subject: |
If you guys are finding it difficult to get the metric nuts and bolts try going to a dismantler and picking the off a japanese car - they use metric fittings. Or even get the nuts and bolts from your nearest Nissan or Toyota dealer.
This is working on the assumption that the Japanese haven't specially changed all their fixings from metric to imperial to suit the American market.
If you get stuck I'm sure thos of us in Aussie or New Zealand coud help you out as just about everything in our hardware shops is metric _________________ Remember a Porsche is not just for Christmas,
