Posted: Mon Sep 27, 2004 2:09 am Post subject: Correct way to set my timing. |
it runs 'Ok' though Im thinking its to retarded so
Ill set the timing mark dead on with the gun then the book say '-3'
at 950rpm is that retarded 3 ' seems it should be advanced 3'.
Im stuck here.
Is there any way to check advance timing at a given rpm with gun
a have a dial for preset timing advance settings guess I just hook it up and unhook the vacuum dizzy tube and rev it up to 4500 rpm set with 41 'advance.
Someone help me here I want to get this done today. K _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
FrankNL
Joined: 13 Sep 2004 Posts: 9 Location: The Netherlands
Posted: Mon Sep 27, 2004 2:45 am Post subject: |
You would like to have a spark BEFORE BDP! So -3 will be 3 degrees before BDP, so before the 0 mark on the flywheel. _________________ Porsche 944 turbo '87 - maranchino red
Porsche 924 '84 - guards red |
augidog
Posted: Mon Sep 27, 2004 11:48 am Post subject: |
Joe,
Look at your manual. With the -3 and the vacuum hoses attached your running actually 3-4 btdc because of the vacuum retard of 7-8 degrees.
Distributor = 30 degrees
Distributors mechanical advance = 6
Static timing = -3
So, to run 41 degrees full advance set it at 2 atdc with vacuum hoses attached. No more than that or you will ping at high rpms
distrib plus mech advance = 36
-3 is static
Vacuum retard 6-8
-3 your actually running at 4 btc with vacuum retard disconnected
4 plus 1 = 5
36 plus 5 = 41
5 is optimal with vacuum hoses disconnected but check your full advance to be sure. 6 btdc and you will ping at 42 degrees.
If all else fails, set it at -3 atdc vacuum hoses connected to be safe. Then you will have no danger of pinging. Your full advance will only be 40.
Anyone who sets 0 or higher " with" vacuum hoses attached will eventually damage the engine.
My vacuum was weak so I had to recalculate from the book. I’m only retarding 6 degrees on my distrib.. That’s why you should do a full advance test to be safe and sure because every car is in slightly different running shape. _________________ 1978 924 95 mile daily driver.
Audi TB/POR174M/High Flow Cat/2.25" exhaust
I knew that positive thinking thing wouldn't work.
Jazzerpet
Posted: Mon Sep 27, 2004 12:01 pm Post subject: |
Augidog, very well put. I will save this info for future reference. I am still amazed at the vast knowledge of our board members. _________________ 1980 931
1985 ½ 944
Member of the “Omaha Crew” |
Posted: Tue Sep 28, 2004 11:22 am Post subject: |
K I put some paint in the flywheel mark that helped..set it 3
and drove it to work and amn it was nice. I have to thank you
guys for all the imput all i did was study the manual and though Id ask here.
Thanks.  _________________ 1979 porsche 924 Na
Posted: Tue Sep 28, 2004 3:31 pm Post subject: |
well about 6 deg BTDC is the sweet spot according to Vaughan, which is roughly where I run mine, I really find it hard to look in that small window at the back and I always just tune it by ear and how it responds when I blip the throttle. _________________ 3 928s, |
Posted: Fri Oct 08, 2004 12:08 pm Post subject: |
Well I set it at 2 degrees. Hey I took a nice pic of the little window last weekend also. Ill upload after I get back goin out for a little ...anywho
Ill show you guys where Im aiming at in the window K when I upload the pic. _________________ 1979 porsche 924 Na
Posted: Fri Oct 08, 2004 2:47 pm Post subject: |
Ok heres what I did hooked up the leads to the battery tyhen clamped the
timing light wire to the #1 cyl. lead set my adjustable timing light at 2-3
then lined up the zero with the mark that the blue pointer I added in the pic
points to on the bellhousing. thats with the vac lines still connected..runs not bad doesnt ping
So do I need to set my adjustable advance timing light at 6 then put the
zero mark on the flywheel to the point on the bell housing.
Posted: Sat Oct 09, 2004 12:34 pm Post subject: |
come on does the arrow point to the right spot. _________________ 1979 porsche 924 Na
Roger
Joined: 06 Jan 2003 Posts: 1235 Location: Cordova, TN
Posted: Sat Oct 09, 2004 12:57 pm Post subject: |
I have the same mark, I have allways used it as TDC _________________ 1981 924 NA
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs. |
augidog
Posted: Sun Oct 10, 2004 12:48 am Post subject: |
Joe,
If that is the 0 tdc mark than whatever you set your advance timing light to, that mark will be centered in that window.
For example your timing light is set to 0
if you center that mark you will be at 0
If your timing light is set to 5 btc, than you line up the same mark in the window you will be at 5 btc.
remember 5 btc vacuum lines disconected- or-
-2 atdc with vacuum lines attached.
Timing is everything.Its my passion with this car to get it just right.
Goodluck. _________________ 1978 924 95 mile daily driver.
I knew that positive thinking thing wouldn't work. |
Posted: Sat Oct 16, 2004 11:42 am Post subject: Augidog |
Augidog When you said this it kind of looped me 'well' I
followed the first part where you wrote remember 5 btc vacuum lines disconected I can do that with my timing light how do I do it with
my light to -2 atdc with vacuum lines attached. It would be best to go
to (0) with my light then retard it a bit............ What I did was set it to 5 with out removing the dizzy lines. So instead of going to Zero then retarding a bit maybe Ill just start it up and remove the dizzy lines
set the gun to 5 and set it and try it... I need the sweet spot.
Goodluck.
____________ _________________ 1979 porsche 924 Na
augidog
Posted: Sat Oct 16, 2004 12:11 pm Post subject: |
Joe,
If you can set to -2 with your advance timing light, than the 0 mark is actually -2 because the timing light is compensating to that degree.
Whatever you set the timing light to- the 0 mark in the window is that timing.
For instance:
5 btc set on your timing light -is now the 0 mark in your window
-2 on your timing light- is now the 0 mark in your window.
With vacuum lines disconnected to the distributor, put it at 41 degrees and rev at 4500 the 0 mark should be in your window and you just checked your full advance.  _________________ 1978 924 95 mile daily driver.
