augidog
Posted: Thu Sep 30, 2004 9:26 am Post subject: oil pressure spring fix WOW!!!! |
From day one I have been plagued with the evil red oil-blinking eye.
From day one I've read replace the oil pump spring.
The problem I had was the part # on 924 tech did not work.
I have the right numbers and the parts, its installed and wow!
It is by far the best and easiest improvement I’ve made.
My pressure is far better and I feel it all the way around from idle to high rpms.
I think the compression is better also.Don't hesitate.
Here are the part numbers
Seal ring N 0438152
Spring 068115421
Piston 056115411A
You can see in the picture the different lengths in the old and new spring.
This is how I think it works.
At high pressure the spring is compressed and opens additional ports.
At idle the spring piston seals a port and keeps the pressure up.
If your spring is weak or compressed like mine, this low idle port never seals and the red eye lets you know.
Good luck, it made me happy I hope it helps you out also.
 _________________ 1978 924 95 mile daily driver.
Audi TB/POR174M/High Flow Cat/2.25" exhaust
I knew that positive thinking thing wouldn't work. |
Phogphire1
Joined: 05 Apr 2003 Posts: 293 Location: Portland, OR
Posted: Tue Oct 12, 2004 3:32 pm Post subject: |
Thanks _________________ Extremism in the defense of liberty is no vice. And moderation in the pursuit of justice is no virtue.
Life, Liberty and the Pursuit of thoose that dare screw with it. |
