Help Please - Engine Missing
kidporsche
PostPosted: Thu Oct 07, 2004 8:49 am    Post subject: Help Please - Engine Missing Reply with quote
Driving to work this morning, my engine started missing at low RPM, but once it got above ~2400 RPM it was OK. It stopped doing it for a while, but then started again about 10min later. I have a lack of tools here, so I am limited in what I can do, but I don't even know what the most likely cause is. Can anyone help?
BTW, I am going to try and find some plug leads close by so I can pick them up on the way home.
Also, I want to buy a fuel pressure tester, can anyone recommend someone who will ship to Australia?
Cheers,
Chris
Chris
1981 924 - RoW (Australian) spec
PostPosted: Thu Oct 07, 2004 10:21 am    Post subject: Reply with quote
The trained ear can tell if its a fuel miss or a electrical miss.
though its flat out amazing what new tune up parts will do.
maybe injectors also. though cap, plugs & leads are a good start.
cheers , bud
Joe
D Hook
PostPosted: Thu Oct 07, 2004 11:00 am    Post subject: Reply with quote
Start with the easy stuff first.
Check the plug wires, both on the cap and on the plugs. You may have one grounding out on the hood or the valve cover. Lift the hood at night and see if there's sparks.
Lizard
PostPosted: Thu Oct 07, 2004 11:08 am    Post subject: Reply with quote
replace cap, rotor, plugs and wires as already suggested.
3 928s,
PostPosted: Thu Oct 07, 2004 11:41 am    Post subject: Reply with quote
Engine Missing! OMG at first I thought your engine was missing.
Whew...I'm thankin' God now that all it was is that your engine's missing.
