1979*924
Joined: 18 Jan 2010 Posts: 26 Location: garden city kansas
Posted: Thu Jan 21, 2010 2:53 pm Post subject: More fuel questions.... |
Good evening all. Well, after going through some of the Haynes manual section on fuel systems, I was looking at the pressure relief valve and it appears that someone has attempted to make their own!?!?! They took a bolt, drilled out the center, ground off one side flat ( so the distributor will lay flat on the air sensor plate). Would I be able to get a proper pressure relief valve anywhere? Also when checking the flow and patterns of my injectors, I seem to have one fuel line that delivers ALOT of fuel, one that delivers SOME fuel, and two that deliver almost NONE . I assume that would point to a problem with my fuel distributor? Maybe I should replace it with a know good one? Any body have one just laying around? Anyway thanks for your time on this problem..... |
