timstar924
Posted: Sat Jul 31, 2004 3:18 pm Post subject: Driver door won't fully close |
| My driver door sticks out a bit when closed and i think the stricker doesn' t fully lock in. cus when it is shut and you push on the door it squeeks and mooves in a bit. The passenger door fully locks, when you shut it the door doesn't stick out a bit and you hear the click of it fully locking which doesn't happen on my driver door. My driver door opened once while making a right turn i was lucky it was early morning and there was to traffic. the stricker comes loose and the door doesn't fully lock. I tried to fix it all day today with no luck. I ajusted both the lock on the door and the stricker but it still doesn't fully lock. I don't know what to do anymore. I don't think a mechanic can fix this if i can't . i am going to take it to a shop anyways to see if they can do anything. |
Posted: Sat Jul 31, 2004 3:26 pm Post subject: |
you need to adjust the pole attached to the chassis, however if it is sticking out abit and not fully closing try slamming the door, and I mean hard not light slamming, and make sure that the mechanism in the door is working properly with a screwdriver ie actuating the mechanism as if it were coming into contact with pole on the chassis and making sure that it clicks 2 times, _________________ 3 928s, |
timstar924
Posted: Sat Jul 31, 2004 3:51 pm Post subject: |
| the mechanism seems to work fine when i push it in it click in two times. i did try adjusting the stricker on teh body but i can't get it to work i tried all day today. i'm going to see if a shop can fix it which i doubt cus i tried so hard. shop will probably say you need a new mechanism or something. |
