1980-1982 Vacuum Diagram - Jon Furst?
1982Porsche924
PostPosted: Fri Jul 30, 2004 4:52 am    Post subject: 1980-1982 Vacuum Diagram - Jon Furst? Reply with quote
I've posted this before, and actually got a very good diagram, but when I went back to the topic, the link was broken to the diagram. Jon Furst posted it, and it was really good, and I need it again. Does anyone have this?
No emissions sticker to tell me where they go.
This is the last thing before I fire my engine!
1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose
924 turbo
PostPosted: Fri Jul 30, 2004 11:15 am    Post subject: Reply with quote
Here you go. I uploaded it to my Rennlist site.
FWIW, this is for a North American-spec 1980 924.
Jon Furst
1982Porsche924
PostPosted: Fri Jul 30, 2004 11:47 am    Post subject: Reply with quote
EXACT picture I was looking for. Thanks.
pyromjm
PostPosted: Sat May 07, 2005 3:09 am    Post subject: Reply with quote
Is that the same for an '82? The large one is 10 medieum is 8 and small is 4 mm right?
-Mike
1982 924 NA gray/silver with black int.
pyromjm
PostPosted: Mon May 09, 2005 5:34 am    Post subject: Reply with quote
I think the 82 is different because my carbon canister only has one vacuum tube coming off of it i think.
-Mike
924 turbo
PostPosted: Mon May 09, 2005 9:08 am    Post subject: Reply with quote
The '82 is different. Sorry, I don't have a diagram for you. You might just check under your hood if the diagram sticker is still intact.
Jon Furst
pyromjm
PostPosted: Mon May 09, 2005 9:09 am    Post subject: Reply with quote
nope, i checked a while ago, nothin there just bare metal
PostPosted: Mon May 09, 2005 10:32 am    Post subject: Reply with quote
Here's the sticker on my '82 931 - http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/bdb3&.dnm=29ea.jpg&.src=ph
Most of it should be of no use to you, but the charcoal canister lines should be similar if not the same. The idea of the charcoal canister is to absorb fumes from the gas tank (hydrocarbons) instead of releasing to the atmosphere, there should be more than one line to it to do what has to be done. That is, absorb fumes while you're parked, then release them to the intake the next time the engine's run. You need one large line to the gas tank, another to the intake, plus a small vacuum line to the "purge valve" (aka- "control valve" as labeled on the sticker) that's opened/closed by vacuum that's in turn supplied or not supplied based on engine temperature.
pyromjm
PostPosted: Tue May 10, 2005 1:11 pm    Post subject: Reply with quote
i really need to get my vacuum hoses on, anyone have any idea where to get a diagram for an 82 n/a 924?
-mike
