juno
Joined: 28 Apr 2004 Posts: 200 Location: Up North, United Kingdom
Posted: Tue Jun 15, 2004 7:20 pm Post subject: Broke down last night :( |
Had to call the RAC at 12:30 AM. Took the guy 40 minutes or so to figure out it was a fuse blown. An 8 amp one on the horizontal board.
Are there anymore spares I need to carry? _________________ 1980 924 Turbo RHD. 3" > 2.5" Stainless straight-through exhaust. |
924guy
Posted: Tue Jun 15, 2004 10:21 pm Post subject: |
i carry an assortment of spare fuses, a full set of spare relays, couple of spare belts, some electrical conectors and tape, bit of wire,and small set of tools , a voltmeter,and a roll of duct tape...more on long trips... but i try to keep it light, if found if i cant fix it with the above, its generally beyond a roadside repair anyhow... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
juno
Posted: Wed Jun 16, 2004 12:20 am Post subject: |
That's what I'd got in mind. Those relays can be expensive though. I've ordered a fuel relay (GBP 3 and loads of fuses. I already had a small toolkit and a haynes in the boot.
I need to have the bushes done pretty sharpish, then it needs a bit of a tune up, both of which are beyond my skills, so cash is pretty tight right now.
It seems to go with owning the car though. No regrets here
924guy
Posted: Wed Jun 16, 2004 4:44 am Post subject: |
i collected most of my spare relays from junk cars.. they either work or they dont for the most part.. so i just grab them when i can, test them, and if they work, they go in the spares pile... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
juno
Posted: Wed Jun 16, 2004 8:16 pm Post subject: |
The problem over here is that all the cars in breakers yards have already been stripped. There's quite a few specialist Porsche breakers with 924's and 944's, but they know the value of the parts, and want a reasonable amount for parts. £15-25 + 17.5% VAT for relays.
I knew it wasn't going to be a low cost car though. _________________ 1980 924 Turbo RHD. 3" > 2.5" Stainless straight-through exhaust. |
