2.5 to 2.8
Dave
PostPosted: Thu Aug 09, 2001 3:51 pm    Post subject: Reply with quote
Is it possable to bore a 924S engine out to 2.8 liters???? If so would I have to get bigger pistons or just oversized rings???
924 turbo
PostPosted: Thu Aug 09, 2001 5:07 pm    Post subject: Reply with quote
No, it is probably not possible. That would require a pretty big bore. You'd have to bore your engine from 100mm to about 106mm. The 2.7l 944 and S2 have a 104mm bore. That is as far as I would go. The S2 has a longer stroke.
Any time you overbore an engine, you always need to replace the pistons.
MAS
PostPosted: Fri Aug 10, 2001 1:50 am    Post subject: Reply with quote
Dave,
Yes it is possible... but you don't have to rebore the engine. All of the 2.5 liter engines can be re-stroked to 2.8 liters. I'm sure that some people here will know the details, but 2.8 liter stroker kits are available.
-MAS
