Unleaded of Leaded Fuel
PostPosted: Tue Jul 24, 2001 12:24 am    Post subject: Reply with quote
Email: Slat@netzero.net
Date: 23 Jul 2001
Time: 23:24:09
Hi, I am considering buying a 77 1/2 924 and would like some help
How do you tell if the engine is intended for use with leaded fuel?
And if so, how does it hold up using unleaded?
PostPosted: Tue Jul 24, 2001 3:17 am    Post subject: Reply with quote
Email: joedanka@hotmail.com
Date: 24 Jul 2001
Time: 02:17:31
I think theres a sticker on the dash that says
unleaded fuel only at least on mine thats what it says. Jd
PostPosted: Tue Jul 24, 2001 8:39 am    Post subject: Reply with quote
Email: Peter@planb.net.au
Date: 24 Jul 2001
Time: 07:39:07
I'm fairly sure that all 924s were designed to run on unleaded. The only difference with the ones built for North America and Japan where unleaded was a legal requirement was the lower compression pistons and the anti-pollution gear (cat. etc).
My '79 runs happily on happily on leaded, lead replacement and premium unleaded. Do not feed a euro/UK/Aus 924 standard (92 octane) unleaded, it gives them very bad indigestion.
Anyway, the valve seats of all 924s were designed to be unleaded friendly.
Peter in Sydney AU.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board All times are GMT + 11 Hours
