bad coolen fan motor , hot runnen924
Guest
PostPosted: Sat Jul 21, 2001 10:59 pm    Post subject: Reply with quote
Email: porsche
Date: 21 Jul 2001
Time: 22:59:41
The existing cooling fan is shit on a 79 924 this is my 2nd 1 thats bit it ... when it needs to be runnen now today it just barely ran causing you know what ... Im goin with a after market 1 directly wired with a switch now .. hat it when it runs hot.. the first 1 s bearing whent out so it didnt spin that freely now this 1 i hokked up with a switch so it would run when i wanted it to
... did i di something wrong ( burn up the fan
motor since like it s supposed to run on amps not full on off the battery or what maybe the connector melted ...Ill check on sunday
Guest
PostPosted: Sun Jul 22, 2001 8:17 am    Post subject: Reply with quote
Email: vscott77@nospam.hotmail.com
Date: 22 Jul 2001
Time: 08:17:32
I wouldn't worry about it too much; just make sure you wire in the aftermarket fan properly. They're so much lighter and more efficient than the original stuff. Got one on my racecar, incredible weight savings... maybe 20 lbs right there! LOL
Oh, yeah, don't worry 'bout Jesus, nobody else pays attention to him anymore anyway
Guest
PostPosted: Mon Jul 23, 2001 4:12 pm    Post subject: Reply with quote
Email: david.c.russell@lmco.com
Date: 23 Jul 2001
Time: 16:12:00
I have been thinking about an after market fan. How good do the cool. What size and CMF rating are you running?
Guest
PostPosted: Tue Jul 24, 2001 10:09 pm    Post subject: Reply with quote
Email: joedanka@hotmail.com
Date: 24 Jul 2001
Time: 22:09:15
I just got it its a summitt adjustable 14' 2,300 cfm.
The only bad thing is it doesnt have a shroud..
$74.88 summitt racing#320714
