Mark CSC Guest
Posted: Thu Aug 09, 2001 3:06 am Post subject: |
I have got my hands on a spare air box cover and have heard various reports about performance gains when drilling it. Anybody done it and what happened?
Also how many holes should I drill and where?
If you think this is a stupid idea please tell me.
Ta
Mark
PS It's great having the new board |
larso Guest
Posted: Thu Aug 09, 2001 3:12 am Post subject: |
i think it would be better to take a big tube and run it somewhere like maybe in one of the fog light holes, remember that there is heat in your engine, I am not sure but maybe drilling holes would allow more hot air to go into your engine than the stock system, some dude sut up his air box on the 924NA and he lost performance, if u go to http://www.924.org and search through the info.
Cutting holes might not work as just having one big huge opening? if you think about it on the exhaust system...if you put holes in the pipes all over it would suck right, i think it would not be as harsh on the intake, but a similar effect?
Cutting up air box makes a nice sound always...psychologically it feels like you have more power, same with all the K and N young bolt on power 944 fanatics i see on the internet with no REAL mods. |
Posted: Thu Aug 09, 2001 11:45 am Post subject: |
don't do it.
The only thing that will happen will be more intake noise and possibly an undetectable drop in power because once you cut the elephant trunk off you're sucking air from higher in the engine bay where the air is hotter.
The reason for the snorkle, apart from reducing noise is to suck air from a low, relatively cool position. If you must do something, extend the snorkle to somewhere outside the engine bay.
The PO of my NA hacked the snorkle off the airbox and it took me forever to get motivated to replace it. I made a custom pipe from 3" pvc waterpipe which points forward, epoxied in place and painted black. Looks good, reduced the noise and made no difference in performance al all.
Mark CSC Guest
Posted: Fri Aug 10, 2001 1:28 am Post subject: |
Thanks Guys
I won't do it now.
Mark |
AppleBit
numbers Guest
Posted: Sat Aug 18, 2001 7:33 am Post subject: |
I have cut the front out of a spare lower box on my 931 so that the air from three of the four hood vents flows directly into the box. This should be cooler air than what you will pick up with a low hose type pick up because of the heating from the asphault. I have been running it this summer, and haven't noticed any real improvement.
Cbass Guest
Posted: Wed Mar 06, 2002 6:33 pm Post subject: |
Thats a good idea actually. Back in the 60s and 70s, everyone was into ram air, and hood scoops and so on. Some of it actually works. I was on an Aussie website, and they used a pressure switch hooked up to a hose to measure high pressure areas for mounting intakes. What they found was the only real pressure zones high enough to make a difference are at the front of the car. Hood scoops won't do anything for induction, but the air inlets on 931s are just about the right spot.
