JamesWilson
Joined: 10 Jun 2005 Posts: 132 Location: San Diego, CA
Posted: Sat Oct 01, 2005 9:30 am Post subject: |
When the ignition module goes south, does it misfire or just generally crap out? I know the old GM modules used to get heat-soaked and not perform well, but generally did not degrade in performance until they just quit working. _________________ '82 924 Turbo (not stock) - soon returning home?
www.AffordableRacingData.com |
JamesWilson
Posted: Sun Oct 02, 2005 11:13 am Post subject: |
Car still behaving badly, but have a few updates--
I just repositioned the DITC board in its box so that it slides in the slots/grooves in the sides of the box...that way, there is no question as to how its positioned or is grounding a resistor, etc.
I also finally pried the flywheel position sender off of the DITC and cleaned it, snapped it back on...that was the one connector that I had not had a chance to clean. Still have NOT gotten around to removing the flywheel end of the sender and cleaning it (if needed at all).
Turn signals have been weak, discovered a burned-out Flasher relay is to blame...signals still light off and flash, albiet weakly, but definitely burn marks on one of the relay prongs. Will replace when I find one.
Still need to purchase some heatsink goo and put it behind the ignition module. I still have a couple of feet of 2-gau cable and a pair of terminals, so another big ground will go on the engine....I'm out of 1/0 cable, dang it!
I will try to drive the car around tonight and see what is what, just wanted to keep everyone updated who has been helping me diagnose this problem of mine.
-JW _________________ '82 924 Turbo (not stock) - soon returning home?
Racing
Posted: Sun Oct 02, 2005 7:42 pm Post subject: |
James.
Are you anal about keepin the stock unit?
If not,be open about the fact that a LOT has happened in the last 20 odd yrs when it comes to digital circuitry.
Seing that..
What i did when i juiced the livin crap outta mine was to ditch the entire innards of the stock dist(in your case that would mean finding another VR sensor for the flywheel recess)and install one out of a later model VW rabbit.
In your case iīd bet that there are VR sensors to be had all over the place.
Volvos..SAABs,VWsBimmers asf.
Then i took that signal and led it into an aftermarket piggy back
In my case it was a perfect power SMT6.(South African by origins)
Had that trigger an MSD unit,but then again with the boost levels i was at it was needed and you could basically have triggered any ign amplifier.OEM or aftermarket-your choice.
What iīm tryin to say is that if this pulls your leg as much as it does..thereīs really no need to cross the bridge for OEM Porsche parts to solve the dilemma.Having cost in mind.
If...you ainīt anal about keepin your car all Porsche that is.
One of the prime advantages of the SMT-dependant on how you look at it-was that i was able to program the timing curve to my liking.
Easy enough,and at the elevated levels of boost i was running i really had no choice.
If memory serves me we ended up@14 deg@2 bars with the K27 compressor and an outlet temp from the IC of just below 40 deg celsius.
Again-if memory serves me-the stock timing was @24 deg at full stock boost.
Seing that,and that an engine like the 31 likes a "lot" of timing when off boost to deliver..
Iīd put light load timing just shy of 40.
Idle..where it needs to be to pass sniffers-Ie;around the 6-8 mark. |
JamesWilson
Posted: Mon Oct 03, 2005 6:55 am Post subject: |
I'm not at all particular about keeping Porsche parts in that car, half of them have VW/Audi logos on them anyway
I'm just interested in something that works and is available in the US. Any help with what VW distributors and/or parts that would work? I don't mind ditching the flywheel trigger and having a Halls sender or something else inside the distributor. _________________ '82 924 Turbo (not stock) - soon returning home?
JamesWilson
Posted: Tue Oct 04, 2005 11:54 am Post subject: |
FWIW, I stopped by Kragen/Checker/Schucks tonight and had them test the starting and charging system.
New Total Power dry-cell battery rated at 1200 cranking amps is only putting out 290cca, and the alternator is putting out around 12.8volts (Bosch reman alt).
Any thoughts as to how this would correlate to my high-rpm misfire? _________________ '82 924 Turbo (not stock) - soon returning home?
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Tue Oct 04, 2005 2:49 pm Post subject: just some late night thoughts |
how are your under dash grounds, the main cluster?
firewall ground?
and bellhousing ground?
you said hitting the brakes caused it to die, I wonder how your vacuum system is doing.
Also runs like crap, define that, is it a loss of power, extra fuel smell, missing.
And is it cutting out under load or no load at the 3200 mark. And does that mean it dies sharply? You might have a busted wastegate bladder, depends if you've been fixing leaks to the intake and vacuum system
I'm trying to see if you have a vacuum leak , you got good brakes?
The TPS switch, have you pulled the TB off and popped the cover and cleaned the contacts, don't remove the switch just clean it. _________________ Bob Dodd - 924turbo@cox.net
JamesWilson
Posted: Tue Oct 04, 2005 4:58 pm Post subject: |
Brakes had nothing to do with it, a sharp bump or weight transfer sometimes causes problems, leading me to believe these issues were only electrically-motivated. Vacuum is good, added upper engine grounds but have only had the car on a lift once-- not checked lower grounds. Where are they/should they be located? I have some length of 2ga and 1/0 ground cables that need a home.....best places to place?
Right now the grounds are as follows-- 2ga from battery neg to chassis, 4ga battery neg to #1 cyl intake manifold bolt--shared with 2ga alternator to intake manifold. 2gau from throttle body to coil mount. I would like to put a 1/0 down below now that the A/C has been deleted, as well as a 2ga back at the transmission. Would that be sufficient?
Where is the main cluster ground behind the relay board that people talk about....will I have to remove a lot to get to it?
Wastegate has just been replaced with a stock, good-working 930 unit with new pressure lines from intake pipe and another to the DITC.
The car has intermittant misfiring (intermittant as to its rpm location, and is NOT boost sensitive). When I bought the car, it was overboosting and running lean and would do its fuel cutout at overboost and would cut out between 3500-4100rpm, all new cap/rotor/wires/plugs/O2/fuel filter. Then after richening the mixture and replacing the wastegate, it still cut out around 4000-4300rpm. I replaced the coil and spark plugs (again), and suddenly I had nearly to 5200rpm to play with!! We also deleted the A/C and replaced a bad fuel hose to the fuel pump and cleaned out the pump screen, making it run definitely richer. Still no change, cut out at the same rpm even with richer mixture....maybe too rich? Then stupid me I tried to clean some of the connectors in the engine bay and the DITC connectors, and lost down to 3000rpm.
The cutout used to feel like a soft electronic limiter (like an old MSD system), not a slam-your-face fuel cutout (overboost). Now, with the seemingly fatter mixture, it feels more fuel-related and pops and backfires if you hold your foot into it even after hitting whatever magical rpm limit I may have for the day. Some days the car feels like a dog below this limit and the boost seems sluggish to come on, other days (like today) it drives great and has smooth strong power delivery all the way up to that rpm limit, which usually raises another 400rpm or so when its running well. BTW-- overboost switch is grounded out, it used to run like crap with it attached at all rpm, so I just grounded it...boost gauge never goes above 11psi.
I am taking the car in again tomorrow morning to have the fuel mixture checked. I also NEED to add grounds, but its tough to find time to be beneath the car (no worky on cars at an apartment, and too many racecars in our shop to feasibly use the lifts).
I'd really love to focus on getting the car prepped and painted, and then re-sort the suspension, but if its not running properly then I'd rather not throw money at other areas of the car, even if they are equally in need. _________________ '82 924 Turbo (not stock) - soon returning home?
Racing
Posted: Tue Oct 04, 2005 5:38 pm Post subject: |
James.
1/The innards from any euro VW late 80s/early90s rabbit will work.
Easy to recognize at the yard,as itīll have a contact at the dist with three wires to it.
An easy mod,as the only thing needed to install is that you break one of the tabs on the ign plate that you put into the 31 dist off.
2/Iīve encountered Porsche modules that,as many others,had the need to be resoldered.
Iīve youīve got a soldering iron,and know how to work it..
Donīt be afraid to take the board out of its shell and attacking it with the soldering iron-just to make sure.
Earlier ones for instance has a tendancy to take in water and it amongst other things has a ceramic resistor thatīll burn one of its legs off.
In that case..you just drill the rivets out and resolder.
Just a hunch..but why would the DITC unit be any different in that respect? |
Racing
Posted: Tue Oct 04, 2005 5:47 pm Post subject: |
On the other matter of the cluster...
Get into the drivers side foot well on your back with some sort of light.
Yeah,i KNOW itīs a bitch..
From the fuse panel towards the front-up at the cowl-youīll see a bunch of brown wires that are hooked to two "stars".
Taking that apart and cleaning it out as well as puttin some copper grease on it..will remedy a LOT of electrical gremlins in the 24/31/44 asf. |
Joined: 29 Jul 2001 Posts: 8968 Location: Royal Oak, MI, USA
Posted: Tue Oct 04, 2005 10:32 pm Post subject: |
I've had the bump-sensitive misfire. That was, in my case, caused by corrosion on the connectors (on the DITC) for the flywheel sensor. It would even backfire sometimes.
No longer a problem. Using my original DITC, distributor, etc., the only running problem I have at all now is a mild off-boost misfire. This I believe is due to one remaining vacuum leak at the compressor bypass valve (on the turbo). I have to go in and replace steering rack boots here shortly, and plan to do it at the same time. _________________ Vaughan Scott
JamesWilson
Posted: Wed Oct 05, 2005 2:18 pm Post subject: |
UPDATE--
Did nothing but reinstall the OLD Jacobs OmniPack ignition system with spiro-wound wires and put new nubs in the end of the spark plugs...plugs looked brand-new when I pulled them out. Only other thing of note was I plugged in the Overboost switch, as it had been grounded.
Car takes a TON of battery juice to get it started, but holy crap does it SCREAM! Huge power all the way to 5100rpm, where it does a violent fuel-cutout-overboost-thing...but at 10psi only. I dunno what it its, but the car has never run better or stronger.
Thoughts? _________________ '82 924 Turbo (not stock) - soon returning home?
Tigger937
Joined: 11 Apr 2004 Posts: 919 Location: PCA Milwaukee Region
Posted: Wed Oct 05, 2005 2:41 pm Post subject: |
Many years ago, I had a problem that was similar to this. I had recently replaced the plug wires with aftermarket that were supposed to be for a 931. After installing, I immediately noticed more power across the band. Boy, did it run nice.........................for about 100 miles that is. Then the car started to miss. Took it in and the mechanic discovered the wires were non-resistive, ie., the plugs were getting too hot a spark for the heat range and subsequently began misfiring. He replaced the plugs with new, and put the old plug wires back in. Misfire was gone.........everything was back to normal.
I've always wondered, what if I were to go back to non-resistive wires and switch to a cooler range plug. Would I get the power increase across the band again or would I cause other problems with the stock ignition system? _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
JamesWilson
Posted: Wed Oct 05, 2005 2:45 pm Post subject: |
Interesting, never heard of that problem, though turbo cars are more sensitive to this than would a NA car.
FWIW, I had been using Kingsbourn wires (usually excellent) in an 8mm outer case, solid-core, with Beru connectors with "5K ohm" stampings. Plugs had been NGK BP6ES non-resistor plugs at the advice of a local Porsche shop, and then changed out to a new Bosch coil and Bosch W5DC non-resistor plugs per my OEM Porsche Repair Manual - USA model (differs from label on fender which calls for a Resistor plug...hmmm).
I may end up going with a WR5DC, but don't want to jinx it.
Tigger937
Posted: Wed Oct 05, 2005 3:02 pm Post subject: |
| JamesWilson wrote: | | FWIW, I had been using Kingsbourn wires (usually excellent) in an 8mm outer case, solid-core, with Beru connectors with "5K ohm" stampings. -JW |
I believe the stock wires are 5K. I know the stock ignition system is sensitive to resistance values of the components since that determines voltage value. If you switch to a non-resistive plug, you may have to switch to plug wires with a different ohmic value to compensate. Anyone here know for sure about this? Also, I know one of the main reasons for resistive plugs is for noise suppression, ie., less interference with radio reception and other systems. There may be other reasons too. Obviously, all this affects spark and as you said, turbo cars are MORE sensitive to this. Anybody here ever play with indexing plugs on these cars? _________________ 1981 931 (Concours)
JamesWilson
Posted: Wed Oct 05, 2005 3:28 pm Post subject: |
No experience with indexing on this car (made marginal difference on a SCCA Solo Stock class 1.5L Honda CRX), but I do know that with increased boost, spark plug gap becomes critical as well. I couldn't keep my 24psi Merkur XR4Ti used to require a tighter gap as boost increased, but also more spark energy as the fuel/air mixture is compressed far beyond what was originally specified.
Any gapping rules with increased boost? What is the correct plug gap on a ROW 931? How about a Carrera GT...GTS....(as the boost and mods increase)....
