vw diesel 924
PAB
PostPosted: Mon Aug 09, 2004 12:11 pm    Post subject: vw diesel 924 Reply with quote
I have a '77 924 Martini, the engine is noisy(bad). I would like to install a mid 80's 1.9 vw diesel. My 3 most important questions are, will the block bolt up exactly, is the clutch/pressure plate the same and would the diesel engine lay at the same angle as the porsche engine or will the diesel's height force me to cut the hood? Thanks for your help
moT356
PostPosted: Mon Aug 09, 2004 1:00 pm    Post subject: Reply with quote
PAB -- We need to talk!
I have a '85 Quantum TD 1.6L engine and I'm looking for a 924 to put it into. Just today I found a '80 NA 924 only about 6 miles from my house. It's not rusty but it has a few dents and it's been sitting a long time (since '96). The owner wants $500 for it, and even though I think it's a little high for the condition it's in, I think I'll go for it.
In regard to the mounting angle, if you use a diesel from an Audi, it will be set up to mount at the same slant as the 924 engine, as that is the way they all are mounted (with inline, not transverse engines). As the VW Quantum is just a rebadged Audi 4000, it should bolt right in. I'm not sure if the 1.9 liter diesel was used in any Audis or Quantum/Passats (maybe in Canada?), but if you found one of those it should work fine. You also could look into mounting the oil pick up and pan from a slant engine on your 1.9, that might work too.
The bolt circle will be the same, as all early 4 cyl. VWs use the same pattern.
Motor mounts are yet to be determined, as is the clutch, but I'm sure something can be worked out
Llamaguy
PostPosted: Mon Aug 09, 2004 2:26 pm    Post subject: Reply with quote
you might run into problems burning the clutch with the diesel's high torque
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
titchati
PostPosted: Mon Aug 09, 2004 3:11 pm    Post subject: Reply with quote
Hello !
A Diesel in a Porsche...
Such a shame
See ya!
87' 924S for every day,
83' 924 for the track !
PORSCHEV
PostPosted: Mon Aug 09, 2004 8:48 pm    Post subject: Reply with quote
My daily driver is an 88 Jetta diesel and I have a spare engine in my shop. I thought of this swap some time back and tried the Porsche bell housing onto the diesel block and it's completely different. The other problem you will run into on the diesel VW's is that some use the starter on the pressure plate and not the flywheel.
All said..it could still be done.....be really simple if you had an automatic 924.
1978-#53 "D" track racer.
moT356
PostPosted: Tue Aug 10, 2004 4:37 am    Post subject: Reply with quote
The Quantum engine has a conventional ring gear on the flywheel for starting.
As for the bellhousing bolt circle, the Quantum engine is bolted up to a Audi 4000 tranny now. I guess the question is will a Audi 100 based engine (924) bolt up to a 4000 gearbox. If not, I guess I'll be making up a plate!
I once saw a Jowett Jupiter (look it up!) with a Vauxhall engine mounted via a flame cut plate, so just about anything is possible
PostPosted: Tue Aug 10, 2004 3:40 pm    Post subject: Reply with quote
the VW block is way smaller, so you would need a custom bellhousing, the crank bolts are completely different so you would also need a custom flywheel and then the clutch disc might have to be custom made.
as far as mounting it in the bay it wouldnt be too hard to do,
in regards to havig th torque burn off the disc, HA, the VW diesel engine doesnt create near enough torque for that.
3 928s,
moT356
PostPosted: Tue Aug 10, 2004 11:41 pm    Post subject: Reply with quote
I spent some time rooting around in the achives at VWVortex, It looks like the Audi 100 based engine used in the 924 has the so-called "5 cylinder" bolt pattern, even though it's a four
I see two possible ways of proceeding with this swap.
1 -- Saw the bellhousing section off a V Dub tranny, then weld on a flange to mate to the torque tube. This might have some hair on it!
2 -- Plasma cut a plate to match 1.6 TD lump to existing clutch housing. Fairly straightforward, but driveshaft might need to be "lengthened" by thickness of plate (say 1/2"). Maybe could be made up at transmission end connector?
I don't see the need to change flywheels, just to find a clutch disk that will work with V Dub flywheel/pressure plate and driveshaft splines.
I'm commited to this project, so one way or another, it's going to happen --
Or maybe it's just that I should be commited
JoonTae
PostPosted: Wed Aug 11, 2004 9:57 am    Post subject: Reply with quote
Hey man good luck with it! I want to put a 1.9 TDI from a new Golf or Jetta into a 914 or 924 some day. And whoever said what a shame earlier. Why would it be a shame? Your putting a German motor into a Porsche? Would it be a shame then for putting a V-8 also or just cause it's diesel? I have nothing against Monster V-8's in a 924. I think it would be sweet to do one day. I'm looking for mileage more than a boat load of speed. I think whatever you like you should do and you shouldn't bash other people for trying something different. Sorry if this offends anyone but I needed to say it.
Derek
moT356
PostPosted: Wed Aug 11, 2004 11:55 am    Post subject: Reply with quote
Thanks Derek, but I'm too old to worry about what anyone else says anyway!
I'm still driving the same 356SC that I bought for $600 in 1975, so I don't need lessons in Porsche mystique from anyone. I think the best thing about 924s is that they are cheap enough for schumucks like me to afford to buy them to fool around with. Want to put a SBC in one, -- great! Want to put a twin turbo Subaru motor? Buick straight eight? Rolls Royce Merlin? Go knock yourself out!
I did go look at a blown Scirroco tranny that I have in my shop. It splits right behind the bellhousing, so maybe it could be used. The problem is that the goofy motorcycle type clutch release rod would never work for our purposes. Maybe the casting could be modified to accept a more conventional lever action release, but it would take some doing.
I can take a pattern off the trany I have for the VW engine side, does anyone out there have scaled drawings of the 924 bellhousing?
Pat Dolan
PostPosted: Sun Aug 22, 2004 12:05 am    Post subject: Reply with quote
moT356:
I'll hound you to the ends of the Universe (well, the know limits of the internet) to lean on you to look for a 5 cyl diesel to bolt in. IF you can find one (yeah, I have one, but it is staying in my 5000) they are nearly give aways.
The 4000 trans used with the 4 cyl engines has the regular VW bolt pattern. You need Audi stuff for the 924, since, as you are now aware, it is a pure parts box 100LS/beetle (yup)/Rabbit car.
Now you have me looking for another one too, but I would still like a 924S with the 2.5 TDI (although not the cheap way out).
Pat
All kinds of German cars (mostly VW-P-A)
1980 924/M471/going Audi turbodiesel!!
moT356
PostPosted: Sun Aug 22, 2004 10:59 pm    Post subject: Reply with quote
Well, thanks Pat, but I don't need another Prairie hound dog nipping at me, I'm already married to a girl from Winnipeg
If it makes you feel better I'll do some looking for 5000 diesels around these parts and see what I can find. I would also need one with a standard trans flywheel, just to make things even more interesting
Do they use the same flywheel as the gassers? That would certainly help the cause
PostPosted: Thu Aug 26, 2004 12:41 pm    Post subject: Reply with quote
What the redline in these diesels? If its 4500 rpm, you'll have trouble hitting 100 mph with the stock gearing.
PORSCHEV
PostPosted: Fri Aug 27, 2004 10:34 pm    Post subject: Reply with quote
My jetta redlines at 4500....and I don't think I have everhad the desire to go that fast in that old clunker... I don't think anyone dropping a diesel in a Porsche is looking for speed...at least I hope not!
moT356
PostPosted: Sat Aug 28, 2004 6:57 am    Post subject: Reply with quote
A not too frantic cruising speed of 70 mph @ 50 mpg is more what I've got in mind for this project, thank you very much!
