PORSCHEV
Posted: Mon Aug 02, 2004 10:09 am Post subject: PORSCHEV'S Car.......Painted! |
Here are some of the pics of my car more near completion....the engine is now running BARKING!! Waiting for seats and wiring. I also am doing the 5 bolt conversion and throwing out the wheel adapters! Before ya all jump all over me...Yes I am lifting the front end..I have a set of mustang springs going in.
 _________________ 1976 924
1978-#53 "D" track racer.
wdb
Posted: Mon Aug 02, 2004 2:57 pm Post subject: |
| car looks great . you have a brake vac booster , is it the stock 924 booster or from another make of car . how much clearence is between the booster and the valve cover , any chance of the engine moving under load and hitting the booster . |
Posted: Mon Aug 02, 2004 4:48 pm Post subject: |
Looking real nice (the car.. not the legs).  _________________ "..it's made in Germany. You know the Germans always make good stuff."
D Hook
Posted: Mon Aug 02, 2004 6:54 pm Post subject: |
| Very, very nice. I like it. |
PORSCHEV
Posted: Mon Aug 02, 2004 9:28 pm Post subject: |
wdb...The valve cover clearence is tight!!! You almost need a feeler gauge to measure it! It is about 1/4 inch. But when the engine torques it tips up and away from it instead of down towards it. Here is a couple pics of how close it is. Notice the notch I had to take out of the strut tower to make room for the brake line. I moved it so far over and the brake fluid res. only clears the hood by a fraction as well.
1978-#53 "D" track racer. |
Vince Ponz
Posted: Mon Aug 02, 2004 10:33 pm Post subject: |
Looks terrific. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Mon Aug 02, 2004 10:38 pm Post subject: |
Aaaaaaarrrrrrrgggggghhhhhhh!!!!!! Not another yellow one?!
j/k bloke.. looks like a hell of a lot of work's gone on there and it shows in the result. Nice one, well done.  _________________ Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead. |
PORSCHEV
Posted: Mon Aug 02, 2004 10:39 pm Post subject: |
Thanks everybody...it feels nice just to share the pics for the past 8 years of work. _________________ 1976 924
endwrench
Posted: Tue Aug 03, 2004 1:41 am Post subject: |
Extremly clean install!! Almost too clean. Makes it hard to appreciate the amount of work involved
Todd |
1982Porsche924
Joined: 14 Nov 2002 Posts: 679 Location: Cupertino, CA
Posted: Tue Aug 03, 2004 2:39 am Post subject: |
Love the euro bumpers too! _________________ 1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose |
jpab924
Joined: 03 Nov 2002 Posts: 1538 Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
Posted: Tue Aug 03, 2004 6:28 am Post subject: |
Very nice.....wish I had the resources to have a project like that.
Where are you gonna hang the rear lic plate? |
Neil924
Posted: Tue Aug 03, 2004 6:58 am Post subject: |
| jpab924 wrote: |
He's going to drill through the Porsche light piece. |
wdb
Posted: Tue Aug 03, 2004 8:53 am Post subject: |
have you considered contacting some of the car magazines and/or tv shows . I would love to see and hear your car up against a few newer cars on track and make the corvette owner cry like a girly man .  |
wdb
Posted: Tue Aug 03, 2004 9:07 am Post subject: |
| oh I forgot , what make and size engine is it .I dont see an air bleed in the cooling sysytem , if you dont have 1 yet , you could probably just weld an aluminum nut to the top of the thermistat housing and plug it with a bolt and rubber washer . or weld an aluminum radiator filler neck to the top of the therm housing , that would allow the water expansion and refill when cooled .a radiator shop could do it , easy . |
PORSCHEV
Posted: Tue Aug 03, 2004 9:35 am Post subject: |
I don't know where I am going to put the plate..I think I will be building a piece out of fiberglass to fit the contour of the rear valance and hold the plate perpendicular as should be. I couldn't bring my self to putting it on with a couple of dry wall screws.
wdb...I am going to send hot rod magizine a few pics in the spring once I get it on the road and have the interior in. It's not really that great of quality work. Pictures do it justice. The bodywork and paint is really good tho. Looks awsome in the sun. The engine is a 67 chev 327.
I am using an aftermarket 3 core aluminum rad with an electric fan ...although you gave me a good idea. I have to build a new water neck/thermostat housing because I had the one on the car cut and welded to fit under the hood...when it was welded..what we thought was aluminum ended up being ans alloy of some kind and it made a weak porus weld. Anyway...the problem I forsee is the engine getting air lock with the rad cap filler below the highest point of the cooling system. So I am thinking of having a bleeder right on the water neck housing.
BTW there are more pics in V8 topic thread. _________________ 1976 924
