1982Porsche924
Joined: 14 Nov 2002 Posts: 679 Location: Cupertino, CA
Posted: Fri Jul 30, 2004 4:52 am Post subject: 1980-1982 Vacuum Diagram - Jon Furst? |
I've posted this before, and actually got a very good diagram, but when I went back to the topic, the link was broken to the diagram. Jon Furst posted it, and it was really good, and I need it again. Does anyone have this?
No emissions sticker to tell me where they go.
This is the last thing before I fire my engine! _________________ 1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose |
924 turbo
Joined: 02 Nov 2002 Posts: 1566 Location: Simi Valley, CA, USA
Posted: Fri Jul 30, 2004 11:15 am Post subject: |
Here you go. I uploaded it to my Rennlist site.
FWIW, this is for a North American-spec 1980 924. _________________ Jon Furst |
1982Porsche924
Posted: Fri Jul 30, 2004 11:47 am Post subject: |
EXACT picture I was looking for. Thanks. _________________ 1979 Porsche 924 "S"
pyromjm
Joined: 26 Sep 2003 Posts: 154 Location: Cupertino, CA USA
Posted: Sat May 07, 2005 3:09 am Post subject: |
Is that the same for an '82? The large one is 10 medieum is 8 and small is 4 mm right?
-Mike _________________ 1982 924 NA gray/silver with black int. |
pyromjm
Posted: Mon May 09, 2005 5:34 am Post subject: |
I think the 82 is different because my carbon canister only has one vacuum tube coming off of it i think.
924 turbo
Posted: Mon May 09, 2005 9:08 am Post subject: |
The '82 is different. Sorry, I don't have a diagram for you. You might just check under your hood if the diagram sticker is still intact. _________________ Jon Furst |
pyromjm
Posted: Mon May 09, 2005 9:09 am Post subject: |
nope, i checked a while ago, nothin there just bare metal _________________ 1982 924 NA gray/silver with black int. |
Posted: Mon May 09, 2005 10:32 am Post subject: |
Here's the sticker on my '82 931 - http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/bdb3&.dnm=29ea.jpg&.src=ph
Most of it should be of no use to you, but the charcoal canister lines should be similar if not the same. The idea of the charcoal canister is to absorb fumes from the gas tank (hydrocarbons) instead of releasing to the atmosphere, there should be more than one line to it to do what has to be done. That is, absorb fumes while you're parked, then release them to the intake the next time the engine's run. You need one large line to the gas tank, another to the intake, plus a small vacuum line to the "purge valve" (aka- "control valve" as labeled on the sticker) that's opened/closed by vacuum that's in turn supplied or not supplied based on engine temperature. _________________ "..it's made in Germany. You know the Germans always make good stuff."
pyromjm
Posted: Tue May 10, 2005 1:11 pm Post subject: |
i really need to get my vacuum hoses on, anyone have any idea where to get a diagram for an 82 n/a 924?
-mike _________________ 1982 924 NA gray/silver with black int. |
