Darin81T
Posted: Mon May 10, 2004 12:59 pm Post subject: Weight Dist. of LT1 924 |
Jamez and I took the V8 924 to the scales today.
Weight was 2640 lbs
1360 lbs front
1280 lbs rear
that makes a 51.5F/48.5R weight distribution... pretty ####' good I'd say
That's just for all the nay sayers who think the V8 will mess up the weight distribution... |
PORSCHEV
Posted: Tue May 11, 2004 6:25 am Post subject: |
gotta love it! _________________ 1976 924
1978-#53 "D" track racer. |
PORSCHEV
Posted: Thu May 13, 2004 8:39 pm Post subject: |
Where are all the outspoken Nay-sayers when the evidence is in front of them. _________________ 1976 924
speedsta2003
Joined: 12 Nov 2002 Posts: 302 Location: Lincoln, Nebraska
Posted: Fri May 14, 2004 6:00 am Post subject: |
I have never doubted puting a v8 in a 924. Rock on!
Now imagine an LS1 in there, more power, and less front weight. w00t _________________ My Old Porsche Thats Sold
http://members.cardomain.com/jatbballboy15 |
jamez
Joined: 03 Nov 2002 Posts: 401 Location: Chehalis, Wa
Posted: Fri May 14, 2004 7:18 am Post subject: |
An LS1 would be bad ass. it is a very expensive motor though, plus it's intake is taller than the LT1's, so I don't think you could fit it under the hood. besides, its not hard to get 400 rwhp in an LT1. |
dwak
Joined: 03 Nov 2002 Posts: 839 Location: Eastern Ontario
Posted: Thu Jun 24, 2004 10:22 am Post subject: Re: Weight Dist. of LT1 924 |
Darin81T wrote: | Jamez and I took the V8 924 to the scales today.
Weight was 2640 lbs
1360 lbs front
1280 lbs rear
Hi Darin,
The LT1/v8 you used, did it have aluminum heads and any other weight saving on the engine and how much did the engine weigh in at?
I'm seriously looking at the swap for my 931.
dwak the horrible _________________ 2x924NA's for parts
931
924S |
speedsta2003
Darin81T
Posted: Mon Jun 28, 2004 4:47 pm Post subject: |
The LT1 has aluminum heads |
924guy
Posted: Mon Jun 28, 2004 10:20 pm Post subject: |
im impressed!! thats far better than i wouldve of expected... the difference is so small it could probably even be compensated for with a 'glass front clip if one so desired..but im guessing its not even necessary.. thats a good bit of info , thanks for posting it!. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
