BMWRob
Posted: Tue May 25, 2004 12:36 pm Post subject: BeaveRun - NASA/GTS first timer questions! |
Hi everyone-
After receiving lots of GTS emails and hearing lots of good things about it on other lists, I'm finally coming to check it out at BeaveRun in 2 weeks. I have a couple of last minute questions I hope someone can help me with!
1. I'm bringing my crew chief to help me out on as usual. Does he need anything - NASA membership, crew license, etc?
2. What class is my car in???? It's an E36 BMW 325i, prepared to ITS rules. An E30 325 I ran against this past weekend during an SCCA race said he was in GTS2 but if I'm performing the calculations correctly, my car is in GTS3? I thought M3s were GTS3?
3. Last one, will the necessary stickers I need be available for purchase at the event? I emailed Mr. Mansier and he said I'd be able to get my NASA log book at the event, so I assumed the stickers will be there as well, but I want to be sure!
Looking forward to some fun racing in two weeks!
- rob |
bmw22
Joined: 04 Mar 2003 Posts: 33 Location: Mount Pleasant, PA
Posted: Tue May 25, 2004 10:28 pm Post subject: |
Rob
Welcome to GTS Challenge. Here's the short answers to your questions.
1. Your crew doesn't need to do anything except sign the typical waivers at the gate. All grid/pit/hot area rules apply the same in NASA as thet do in SCCA.
2 Sounds like you know your weight and RWHP. If weight/RWHP falls in the 14.5-17.49 range, then you are GTS3. Some M3 are GTS3 and some are GTS4. BMW CCA Stock BMWs are quite heavy and fall into GTS3
3 I'll be at the track with GTS decals for your car.
I'll see you at Beaverun. Get ready for a ton of track time, and maybe even a kart race on Saturday evening. _________________ Mark Barr
325is GTS2 #22
mailto:markbarr@wpa.net |
BMWRob
Posted: Wed May 26, 2004 12:17 am Post subject: |
Thanks Mark!
For my car, I only know the factory hp number (my car has never been on a dyno) and the minimum weight I can run in ITS (although I have scaled the car several times and know I can get really close to that ). If I can, I'll rescale it before the event and there's a dyno shop right down the street who I need to talk to about some exhaust work anyway....
Thanks again, see you in two weeks!
- rob |
BMWRob
Posted: Sat May 29, 2004 2:54 pm Post subject: |
One more question... will there be tire service at the BeaveRun event? Hoosier maybe? |
Joined: 29 Jul 2001 Posts: 8383 Location: Royal Oak, MI, USA
Posted: Sat May 29, 2004 11:42 pm Post subject: |
Gonna have to check with Lawrence Mansier on that... _________________ Vaughan Scott
'79 924 #77 ITB racecar
Posted: Thu Jun 03, 2004 11:36 pm Post subject: |
There's an update of sorts on the NASA forums:
http://www.nasaforums.com/viewtopic.php?t=2527
Long story short, we don't have a committment yet (for sure) that there will be a tire service there. However we have identified a local shop that can handle tire changes just a few minutes from the track:
(From bmw22)
I just spoke with a local tire service. They are open until noon on Saturday. They have equipment that handles upto 24" rims and can handle expensive wheels with out touching them. He used the term "touchless mounting" Mount and balance $19 per wheel. They are just a couple minutes from the track.
Uneeda Tire Co
Address: 508 Glen Ave, Ellwood City, PA 16117
Phone: (724) 752-8473 _________________ Vaughan Scott
