Sorry have to post this again: where to get 0.5mm...
QuadESL63
PostPosted: Tue Feb 10, 2004 6:27 am    Post subject: Sorry have to post this again: where to get 0.5mm... Reply with quote
undersized main bearings?
BTW, can I use the one from other Porsches?
Thanks!
I have tried a lot of places, including the nice folks at PAECO (Carl told me he tried a few suppliers and the bearings are in their "back order" a.k.a. no one has them).
PostPosted: Tue Feb 10, 2004 1:44 pm    Post subject: Reply with quote
Have you tried EBS?
QuadESL63
PostPosted: Tue Feb 10, 2004 2:15 pm    Post subject: EBS? EBS Racing? Reply with quote
Paul wrote:
Have you tried EBS?
Hi Paul,
EBS Racing? http://www.ebsracing.com/water.html Not really... Thanks for the suggestion though. I will try.
Any other suggestion? Thanks!
wdb
PostPosted: Tue Feb 10, 2004 3:23 pm    Post subject: Reply with quote
I have not verified this , but the vw 2.0l main bearings might fit ,they cost about $30 . maybe you could find the specs and compare or gamble and buy a set and see . the rod bearings from the vw 1.9l turbo diesel are the same diameter ,but I dont know if thet are a swap for sure ,cost around $20 . the bearings from a 77-79 amc concorde are a direct swap ,I forget the cost .
also several members have had failures after a rebuild, a few vw/audi guys say to replace the rod bolts when doing the bottom end ,because they are notorious for failing .
PostPosted: Wed Feb 11, 2004 11:33 am    Post subject: Reply with quote
Call toll free: (800) 462 3774
