bogging out at 3500 to 4000rpms
porsche931US
PostPosted: Sat Apr 05, 2003 9:59 am    Post subject: bogging out at 3500 to 4000rpms Reply with quote
I have a 81' 924 turbo that for some reason bogs out at about 3 to 4 thousand rpms. I was just wondering if anyone had an idea about what could be causing this problem . Thanks!
Lizard
PostPosted: Sat Apr 05, 2003 10:17 am    Post subject: Reply with quote
clean/new distributor cap and rotor, basic tune up, or the DITC box, O2 sensor
3 928s,
PostPosted: Sat Apr 05, 2003 12:05 pm    Post subject: Reply with quote
Have a look at my posts here:
http://www.924board.org/viewtopic.php?p=47756
I had your symptoms and the prob was with the lower pressure pipe to turbo connection, and due to lower pressure pipe to block mounting bracket being not attached.
- shamwow guy
Silverarrow
PostPosted: Sat Jul 26, 2003 3:45 am    Post subject: bogs out a 3500-4000 rpm Reply with quote
I had a similar problem with my 80 931. I discovered it needed a better engine ground. Now I get power on to the redline. Also check the fuels supply and filter(s). there are many ways that problem can occur. But a poor ground to the engine can make a lot of problems. Like Do you have a problem with the temp guage not reading properly? Other intermittent electrical things happening? a lot of german car problems seem to be caused by poor grounding of the engine and chassis. I don't post much but I post what I know. Let me know what you find.
1977 924 NA no sunroof
1980 931 With a sunroof
I could be crazy, Oh yes I could!
CMXXXI
PostPosted: Sat Jul 26, 2003 4:18 am    Post subject: Reply with quote
I've had symptoms of running ragged in the upper RPM range because of vacuum leaks. I'd start with the easy to check and fix stuff first, before starting to replace parts. Do as Smoothie suggests and double check your pressure ducting, and it never hurts to verify all your vacuum lines are connected, not broken, cracked or loose.
'79 Eurospec 931
924martinirossi
PostPosted: Tue Jul 29, 2003 1:16 pm    Post subject: Reply with quote
I also had a problem like that and my WUR caused it. The control pressure was the same as the fuel pressure.
Michael
