Fuel pump no pressure go figure
Thom
Guest
PostPosted: Sat Aug 11, 2001 9:49 am    Post subject: Reply with quote
ok so after all the great advice I checked and no fuel pressure. I was given a price at the local of $200. used or $450 new. Oh I have an 81 924. So I said I would go for the used and then I thought. Maybe its just the relay? any info out there?
Thanks
Thom in Barrie Ont.
Mike B
Guest
PostPosted: Sat Aug 11, 2001 12:14 pm    Post subject: Reply with quote
I would check the electrical stuff first as it is cheapest to fix...like the relay, fuse etc...Did you test your pump to see if it is operational of fried...
PostPosted: Sun Aug 12, 2001 3:56 am    Post subject: Reply with quote
Yeah, just jump the relay and see if the pump runs, or if you even get +12V back there...
'79 924 #77 ITB racecar
marky522
Guest
PostPosted: Sun Aug 12, 2001 2:58 pm    Post subject: Reply with quote
If it does end up being the fuel pump let me know i have an 81 924 parts car.
Mark
