cpt_koolbeenz
Joined: 26 May 2003 Posts: 108 Location: Colorado Springs, CO
Posted: Thu Jun 19, 2003 11:34 am Post subject: |
| Quote: | Im confused all i see is the yellow gauge cluster with a yellow trim ring. I paint the damn trim rings what is this for. What is the prodcut being sold.
Same here. Im confused. Which service is being performed? Reverse glow? All of them? I would like to see what they will look like. If they are cool im interested. |
Porschephile
Joined: 04 Nov 2002 Posts: 825 Location: Denver, Colorado
Posted: Thu Jun 19, 2003 2:21 pm Post subject: |
both reverse and regular indiglo are bein done. However, if ya own a 924S or 944 with the MPG gauge in the tach, they don't have the gauge for that. and that is all I'm waiting for before I order. _________________ werd B. |
blury
Posted: Thu Jun 19, 2003 2:57 pm Post subject: |
Well that sucks  _________________ Polish your apc banner and shut up |
Sickofstreetracing
Joined: 11 Jun 2003 Posts: 88 Location: St. Louis, MO
Posted: Thu Jun 19, 2003 3:53 pm Post subject: |
Hey joe, was that center mounted tach a custom guage job, or just a pop em and swap em job you can DIY? _________________ '87 924S Guards Red, Not stock anymore!
-Weltmeister Throttle Response Cam (gotta start somewhere...)
www.cardomain.com/id/wannabedrifter |
cpt_koolbeenz
Posted: Thu Jun 19, 2003 6:02 pm Post subject: |
| Quote: | | Hey joe, was that center mounted tach a custom guage job, or just a pop em and swap em job you can DIY? |
Not sure about an 87 but in a 80 they are all the pop out kind. Just push on the back from under the dash and they come right out. Sometimes they can be stuck in there real well so you have to push hard. Is this the same as in the pic Joe? |
Posted: Thu Jun 19, 2003 6:46 pm Post subject: |
there from a 944 they just push in from the front and are held in palce with a rubber strip wrapped around the guage, I have since switched the tach back over to the far right and put the speedo in the middle, I was just trying it out in the pic the weird way had problems seeing how fast Iwas going alot so I put the speedo back in the middle.  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
cpt_koolbeenz
Posted: Thu Jun 19, 2003 7:38 pm Post subject: |
| Quote: | | there from a 944 they just push in from the front and are held in palce with a rubber strip wrapped around the guage, I have since switched the tach back over to the far right and put the speedo in the middle, I was just trying it out in the pic the weird way had problems seeing how fast Iwas going alot so I put the speedo back in the middle. |
so... yes it is the same  |
Sickofstreetracing
Posted: Fri Jun 20, 2003 4:32 am Post subject: |
Cool, thanks Joe, I might try that out for awhile. Might as well seeing as I have to replace the bulbs in there anyway. (And you thought you had trouble seeing how fast you were going! At night I have to rely on street lights and my dome light! ) _________________ '87 924S Guards Red, Not stock anymore!
Posted: Fri Jun 20, 2003 4:35 am Post subject: |
I swapped the tach and speedo in my NA the speedo doesn't sit 100% but I think it is due to warpage in the dash _________________ 3 928s, |
Sickofstreetracing
Posted: Fri Jun 20, 2003 4:41 am Post subject: |
Any kind of adhesive holding them in the stock position? Anything I could use to make them secure, but still able to remove? _________________ '87 924S Guards Red, Not stock anymore!
Posted: Fri Jun 20, 2003 6:06 am Post subject: |
I dont have a extra set of 944 guages and I dont want to think about
buying a set donate a set for my just cause asnd Ill give you a diswcount on your set of guages. I want a set of early 44 guages or a set of
924S guages. Yes like the yellow ones.
Porschefile you had a set didnt you.
and you Alex you have set you can donate.
I need the whole cluster.
Anyoneelse want to get involved. _________________ 1979 porsche 924 Na
Porschephile
Posted: Fri Jun 20, 2003 6:15 am Post subject: |
No, I didn't have a set. I was gonna be the group leader, and go buy a set from the junkyard. but you took over, so it's not my responsibility. if you want enough orders to get your gauge faces, put in the ones with the MPG gauge in the tach. I'm not dishin out the money for you to get free gauges Joe. It's not anyone's responsibility but your own. and yes, I was gonna send in BOTH tach's.
I'm not buyin a set until someone sends in the MPG gauge tach. _________________ werd B. |
Posted: Fri Jun 20, 2003 6:20 am Post subject: |
| Porschephile wrote: | No, I didn't have a set. I was gonna be the group leader, and go buy a set from the junkyard. but you took over, so it's not my responsibility. if you want enough orders to get your gauge faces, put in the ones with the MPG gauge in the tach. I'm not dishin out the money for you to get free gauges Joe. It's not anyone's responsibility but your own. and yes, I was gonna send in BOTH tach's.
I'm not buyin a set until someone sends in the MPG gauge tach. |
Heres alesson why are you so harsh..just think you could of right
then been the one to recieve a free sdet of guage didnt you read my part
about a discount. Your pretty harsh dude.Dont stare at no more white blank walls no-more. OK
Joe D.
Typing is like playing guitar it only sounds godd if you dont mess up and
the rite key and have the beat. _________________ 1979 porsche 924 Na
Porschephile
Posted: Fri Jun 20, 2003 6:28 am Post subject: |
Whatever. However, unless I get a free set of gauges, I'm not spending more money than everyone else to get the same product. I'm in enough debt right now as it is. I don't see it as bein Harsh, but more as being a smart consumer. I just don't care anymore. count me outa the deal. _________________ werd B. |
924 turbo
Joined: 02 Nov 2002 Posts: 1566 Location: Simi Valley, CA, USA
