bad fuel pump????
Guest
PostPosted: Mon Jul 23, 2001 7:46 pm    Post subject: Reply with quote
Email: stevey9@hotmail.com
Date: 23 Jul 2001
Time: 19:46:23
ok so i'm driving around friday parked for 15min came back started the car and it was running real rough like it was only running on 2 or 3 cylinders. i limped home and parked it all weekend. then today i pulled all the injectors to see if they were all working right. they all looked fine. i put them back in and started the car, it ran great. So i took it for a drive stop and park 3 or 4 times and everytime it started right up and ran great. then i got gas and it happened again and i limped home again.
i think that it might be the fuel pump but i don't know how to check to see if it's bad or not.
any help would be useful
thanks
steve
Guest
PostPosted: Tue Jul 24, 2001 12:23 am    Post subject: Reply with quote
Email: dy15@yahoo.com
Date: 24 Jul 2001
Time: 00:23:59
check all your fuel filters and change them if you have any doubts. Check the flow of fuel out of the tank before the pump, if need be clean the tank out. Then check your fuel pump for volume and pressure according to the Haynes manual.
Good Luck
