Alcohol injection...mmm...so tasty...21 PSI
Guest
PostPosted: Sat Jul 21, 2001 6:41 pm    Post subject: Reply with quote
Email: rick.maclaren@home.com
Date: 21 Jul 2001
Time: 18:41:10
21 PSI and the knock sensor stays in the green all the way...unbelievable. Exhaust temperature reduced 70 degrees.
Guest
PostPosted: Sat Jul 21, 2001 8:33 pm    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 21 Jul 2001
Time: 20:33:37
wow!
who made the knock sensor? who made the exhaust sensor? where do u get em?
Guest
PostPosted: Sun Jul 22, 2001 10:56 am    Post subject: Reply with quote
Date: 22 Jul 2001
Time: 10:56:32
Defi made the gauges (powder green with red needle) and Sharp made the sensors. You SHOULD use a tie down strap to tie your engine to the frame/chassis to prevent unwanted engine noise...noise makes the knock sensor go wiggy.
