unknown item
924ttrouble
PostPosted: Wed Mar 05, 2003 11:57 am    Post subject: unknown item Reply with quote
What is this item located on the driver side fender in the engine compartment toward the middle with a part number 477.957.901c? The item is square and has a cable on the top one on the bottom and an electric plug on the bottom. Does any one know?
PostPosted: Wed Mar 05, 2003 2:21 pm    Post subject: Reply with quote
That should be the mileage counter for the oxygen sensor light. It just counts off a certain number of miles then closes a switch to light the light in the dash, then you're supposed to replace the oxygen sensor. Them's speedo cables going to and from it. When it's time for a new cable, most get rid of that setup and go with a single longer cable instead - cheaper, easier and way more sane.
924ttrouble
PostPosted: Thu Mar 06, 2003 11:08 am    Post subject: Reply with quote
Thanks for the info, I'm going to try to find the shop manual for this car.
