924 wheel upgrade
PostPosted: Tue Jul 17, 2001 5:48 pm    Post subject: Reply with quote
Email: eskimoheadhunter@hotmail.com
Date: 17 Jul 2001
Time: 16:48:07
Hi,
I have a 1977 924 with the 8 spoke alloy rims. I'd like to put bigger tires on it but I am unsure of what rim size is too big - I don't want the tires to rub on anything except the road.
What is the largest rim diameter and width (front and back) I can go without running into anything(assume low-profile tires)?
What tire brands/models should I look for/stay away from?
Also what kind of offset should I be looking for (is the front the same as the back)?
I've tried researching my questions on this site and www.tirerack.com, and my results have only been inconclusive. Any help from all you experienced 924 owners would be greatly appreciated. Thanks - Jim
PostPosted: Wed Jul 18, 2001 3:18 am    Post subject: Reply with quote
Email: morten_sandvik@c2i.net
Date: 18 Jul 2001
Time: 02:18:08
look at "my car" I have 17x7,5" et 18 rear/front. At rear i you 25mm spacers. For tyre I have 205/40-17.
Also look at : http://www.mobile.de/cgi-bin/search.pl
PostPosted: Wed Jul 18, 2001 8:48 am    Post subject: Reply with quote
Email: merrell@oneimage.com
Date: 18 Jul 2001
Time: 07:48:57
Try the following sites
http://www.discounttiredirect.com/
They actually show what is available for 924's. You can also do a search based on wheel size and bolt pattern.
http://www.superlite-wheels.com/
PostPosted: Fri Jul 20, 2001 10:08 am    Post subject: Reply with quote
Email: ponzv@aol.com
Date: 20 Jul 2001
Time: 09:08:52
I have been tracking my car a 77 924 for the past 10 years with the original setup. I even used the 8 spoke 14in wheels. I changed to the spider web wheels in 15 inches with 205 60 tires and the car performs wonderfully. I still have the revised setup and could not be happier. Spent the extra money on other things.
I have seen 225 on the 15s but don't know if they rub.
PostPosted: Fri Jul 20, 2001 10:27 am    Post subject: Reply with quote
Date: 20 Jul 2001
Time: 09:27:44
This guide is wrong for the porsche 924.
the "et" on a porsche i 20 mm.
You can use this guide : http://www.specialfalgar.se/
look at peugeot 406 96-
morten sandvik
PostPosted: Fri Jul 20, 2001 5:56 pm    Post subject: Reply with quote
Email: david.c.russell@lmco.com
Date: 20 Jul 2001
Time: 16:56:53
The 225's will rub on both back and front. I run 215's on the back, 225's on the front, on 4 lug spiderwebs.
PostPosted: Fri Jul 20, 2001 5:57 pm    Post subject: Reply with quote
Date: 20 Jul 2001
Time: 16:57:41
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board All times are GMT + 11 Hours
