924 S noise underneath
Guest
PostPosted: Thu Jun 28, 2001 10:55 am    Post subject: Reply with quote
Email: toby.shelton@ci.austin.tx.us
Date: 28 Jun 2001
Time: 10:55:40
Need some help; whenever I let off the gas I hear a popping noise underneath the car when coasting. It doesn't do it if I push in the clutch. Does anyone have any ideas what this may be ?
Thanks...
Guest
PostPosted: Thu Jun 28, 2001 9:10 pm    Post subject: Reply with quote
Email: ilavoy2@aol.com
Date: 28 Jun 2001
Time: 21:10:53
popping nose could be cv joints in your axles
Guest
PostPosted: Fri Jul 20, 2001 8:33 am    Post subject: Reply with quote
Email: jkmtyler@tiac.net
Date: 20 Jul 2001
Time: 08:33:24
Toby,
I have the same exact problem, although I don't know what the fix is. with mine it was like a clicking noise starting from zero, and when I put the clutch in... nothing? I thought it might be a drive shaft or something, when I went to have it looked at, it stopped... then came back... then stopped again (for the past few months) I thought it might rain or extreme heat/weather related expanding a joint or something.
Anyway... sorry no solution, but I'm glad that someone out there has the same problem... if you find the solution, please post it for me, so I can get mine into the shop to have it looked at
thanks,
Jim
