BauerR
Joined: 13 Apr 2022 Posts: 10 Location: Baltimore, MD
Posted: Wed Jun 21, 2023 12:48 am Post subject: Ignition coil upgrades? |
Hello all.
Looking to replace an original (42 y/o) ignition coil on a US '81 S2.
Wondering if there are any upgrades exist?
Thanks _________________ 996 Turbo ('04)
911 Turbo 930 ('84)
928 S4 auto ('89)
928 S4 manual ('87)
957 Cayenne Turbo ('09)
931 Turbo S2 ('81)
951 Turbo ('87) |
chuck21401
Joined: 20 Feb 2005 Posts: 532 Location: Annapolis, MD
Beartooth
Posted: Tue Jul 04, 2023 2:44 pm Post subject: |
I had a MSD Blaster 2 coil sitting around, so I put that in my car. It runs fine and no issues I can tell, but I haven't put any significant miles on it. The coil that was in it, and I'm not sure it was original, reads in at 1.0 ohm primary resistance, where the Blaster shows 0.9. It's a popular coil for V8 applications; I'm not sure it's meant for six or four-cylinders, but MSD doesn't give any warnings against that in the instructions. Time will tell, but being almost the same resistance tells me it should be ok. Mine's an '80, so it's the old setup with a resistor wire to the coil. If that's the setup you've got, I think any generic performance coil should work as long as it's not one meant to only be run on a capacitive discharge setup. If you've got DITC, then I'm not so sure except to say you could run into trouble if you put something in with too low primary resistance. I do see that they used a different coil with DITC, but I can't find any specs on it. _________________ 1980 931 diamond in the rough |
BauerR
Posted: Wed Jul 05, 2023 3:27 am Post subject: |
Thanks, I have the Blaster 2 on my 951, so def no issues on 4cyl applications.
As far as DITC is concerned, I'll have to look further into that.
Thanks for the feedback _________________ 996 Turbo ('04)
911 Turbo 930 ('84)
928 S4 auto ('89)
928 S4 manual ('87)
931 Turbo S2 ('81)
951 Turbo ('87) |
MikeDanger
Posted: Wed Nov 29, 2023 6:14 am Post subject: |
any new findings here? what Ohm is preferable for S2 DITC? _________________ It was either this or a giant box of legos |
BauerR
Posted: Tue Dec 12, 2023 11:06 pm Post subject: |
I put a Blaster 2 on the 931(S2)
Zero issues _________________ 996 Turbo ('04)
911 Turbo 930 ('84)
928 S4 auto ('89)
928 S4 manual ('87)
931 Turbo S2 ('81)
951 Turbo ('87) |
