Where does it go?
BillA
PostPosted: Thu May 18, 2023 2:47 am    Post subject: Where does it go? Reply with quote
Does anyone have any ides where this connects to on the backside of the fuse block in the G section 1-9. it is the white wire I've seen posts related to this wire (white) and there doesn't seem to be a definitive answer. Trying to sort out no low beams. I think I've read every post about this subject still troubleshooting
Thanks.
BillA
1981 931
bear924
PostPosted: Thu May 18, 2023 9:09 am    Post subject: Reply with quote
Hi Bill,
I suspect we are both working on similar faults at the moment. The specific pin is the number at the point you've highlighted (your pics's resolution isn't good enough to see number and my drawings are elsewhere atm).
When I did my fault finding, I discovered that my pin had failed within the fuse box .. is short, the power come out of the fuse wasn't making it to the plug connection.
