Joined: 29 Jul 2001 Posts: 8815 Location: Royal Oak, MI, USA
Posted: Thu Nov 11, 2021 11:03 pm Post subject: |
Correct; one is signal from the Hall effect sensor, the other is the shielded ground for the co-ax wire.
Not sure how best to connect to an MSD, though. _________________ Vaughan Scott
Posted: Fri Nov 12, 2021 12:13 am Post subject: |
Gone for a couple of days, I'll get the get the diagram for the MSD when I get back. _________________ Mike
'67 MG Midget Dp
ChrisCXC
Joined: 18 Oct 2019 Posts: 19 Location: Los Angeles, CA
Posted: Fri Nov 12, 2021 7:06 am Post subject: |
924RACR wrote: | Correct; one is signal from the Hall effect sensor, the other is the shielded ground for the co-ax wire. |
Interesting. I think I missed that ground. I will fix that! |
ChrisCXC
Posted: Fri Nov 12, 2021 7:12 am Post subject: |
MikeJinCO wrote: | Gone for a couple of days, I'll get the get the diagram for the MSD when I get back. |
Awesome, thanks! I've been using the MSD diagram, but I wasn't sure what type of distributor I'm using.
Here is the instruction book: https://documents.holley.com/6425.pdf
I assumed it was a Points/Amplifier Style Ignition. Thus my my white wire is going to that center wire from the coax cable on the distributor.
I then figured my red wire was going to the "Z" terminal on my cutoff switch (where the ignition coil is on the diagram for the switch):
Posted: Sat Nov 13, 2021 5:10 am Post subject: |
MSD Wiring:
Heavy Red to battery positive.
Heavy Black to Ground.
Orange to positive on Coil
Black to negative on coil
Violet(purple) to Positive on distributor-
Green to negative on distributor.
White wire NOT used.
I don't think there is any actual polarity in our distributor, but mine are wired, PIN toward FRONT purple, Pin toward BACK green.
If you are using the stock tachometer the is something needed to make it work right. Someone else will have to chime in on that.
Hoe this helps _________________ Mike
'67 MG Midget Dp
ChrisCXC
Posted: Sat Nov 13, 2021 9:36 am Post subject: |
OK, perfect. Thanks! |
ChrisCXC
Posted: Thu Dec 02, 2021 4:34 am Post subject: |
Where do you guys get your clutch parts from?
Any recommendations on what we should use? |
Posted: Thu Dec 02, 2021 9:35 pm Post subject: |
Been a while since I bought one, but we're using stock Sachs. Heard too many stories about bad aftermarket clutches from other racers... Centerforce comes to mind... _________________ Vaughan Scott
ChrisCXC
Posted: Fri Dec 03, 2021 2:43 am Post subject: |
Understood, thanks!
We were thinking of using the South Bend Clutch Stage 2 Endurance kit.
Any thoughts on a flywheel? Ours is missing teeth..... |
Posted: Fri Dec 03, 2021 4:49 am Post subject: |
I'm building a higher power NA motor so I quizzed morghen about the clutch he is using with his supercharged car. He said that the stock Sachs has been working well. Not knowing the cost of the South Bend unit I wouldn't spend extra to get it. _________________ Mike
'67 MG Midget Dp
Posted: Fri Dec 03, 2021 4:53 am Post subject: |
I remember years back Raceboy kept a stock clutch in his turbocharged NA also. _________________ Mike
'67 MG Midget Dp
Joined: 28 Feb 2008 Posts: 1361 Location: Washington DC area
Posted: Fri Dec 03, 2021 11:27 am Post subject: |
I've been running stock clutch discs in all my Porsche, BMW and Benz race cars for over 40 years. Never had any of the problems my competitors did with their fancy clutch packages. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
ChrisCXC
Posted: Tue Dec 07, 2021 2:26 am Post subject: |
Great info guys, thanks.
Where do you guys like to get your stock clutches and flywheels from? Pelican (our normal supplier) seems to be out of stock. |
hayeslewis
Joined: 21 Aug 2011 Posts: 74 Location: Alexandria, VA
Posted: Sat Feb 05, 2022 6:55 am Post subject: clutches flywheels |
FCP euro has them. I've found them on ebay. You should be able to machine the flywheel. _________________ Hayes Lewis
1979 924 HP
1979 924 ITB/HP???
2007 Armada
2013 Hyundai Elantra
1972 MG Midget Vintage project
Unstable electrified three wheeled Bicycle truck |
