Battery Compartment
jeneese
PostPosted: Tue Apr 13, 2021 6:49 am    Post subject: Battery Compartment Reply with quote
Any new methods of repairing or replacing a 924 rusted battery compartment. Maybe a replacement sheet metal compartment replacement if somebody makes them. Would like to do this right, not all the bondo and fiberglass "repairs" I have seen in the past.
Jim
Porsche 1982 Euro Spec 924
BTRacing
PostPosted: Tue Apr 13, 2021 11:47 pm    Post subject: Reply with quote
There is no replacement panels available as far as I know. I repaired my 925 turbo with piece cut out from the other car. Complicated repair if you want to do it right. Metal has multi layers in some spots and there are blind compartments impossible to weld. Find a clean 0an from parts car, cut it way bigger then what you need and then start drilling out spot welds and trim as necessary.
www.btr-chicago.com
1977 924 Martini
1979 931 GTR Le Mans replica to be
1993 Mercedes 190E Sportline LE, one of 700 made
2020 Ford F350 Tremor daily driver/tow pig
1974 Moto Guzzi Cafe Racer
2002 Formula Fastech 382
jeneese
PostPosted: Wed Apr 14, 2021 12:35 am    Post subject: Reply with quote
Thankyou for the quick reply. I was afraid the answer I would get but such is life. Also checking in Europe and see what they do but probably the same. To find a donor car here in the rust belt is impossible but will keep trying. Thanks again.
Jim
Jim
