Posted: Mon Mar 01, 2021 6:31 pm Post subject: |
This link does not work for me for some reason.
Amazing effort!
We're lucky to have people like you in our comunity. _________________ SUPERCHARGED Ruby-sh 924 |
Joined: 14 Dec 2004 Posts: 1101 Location: Chicago-ish
Posted: Tue Mar 02, 2021 1:45 am Post subject: |
That's funny. Worked for me last night and now it doesn't!
I only tried it there because Vimeo wouldn't upload. I'll figure it out. The Al Torque Tube 9000rpm test and run-in might go to YouTube
Thanks! I just want to contribute something even if it can be a bit off the wall at times. I feel like I am a piece of the total puzzle with everyone here filling in the the other pieces. I'm constantly learning from you other puzzle pieces , thank you! _________________ 1980 931 since 1989
MOTANUL
Joined: 19 Nov 2018 Posts: 157 Location: ROMANIA BUCHAREST
Posted: Tue Mar 02, 2021 11:18 pm Post subject: |
Can anyone help me with an equivalent available for this kit? https://www.123piecesderechange.fr/pieces-auto/fa1/p-14467972
The problem is that I can't find it available anywhere.
 _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979 |
Posted: Wed Mar 03, 2021 3:32 am Post subject: |
Just search “k26 rebuild kit” on eBay, but it won’t have the 931 specific exhaust gaskets.. _________________ 80 Turbo - Slightly Modified |
MOTANUL
Posted: Wed Mar 03, 2021 7:31 am Post subject: |
The parts inside were easy to find. I only find the connecting parts individually at the Porsche dealer.
An idea of a thermal protection shield for exhaust.
Posted: Wed Mar 03, 2021 12:41 pm Post subject: |
Had an idea to measure the backside of each wheel fitted in their respective housings after my last machining pass. The magic happens when new 2667 curvature machining starts to clean up the previous 2664 curvature almost entirely....The wheel backside to housing dimensions are essentially identical. This means it should be bolt on from here on out
Posted: Thu Mar 04, 2021 6:41 am Post subject: |
it works! Working on getting a video up for you to see (what a convoluted way to get it to Vimeo but here it is)
https://vimeo.com/519169595
This is the wheel put into the housing before assembly showing the wheel curvature following the newly machined housing. I assembled a turbo loosely and it spins. Bore camera shows it right up on the housing as it should be. Might need to adjust clearance but it's going to work!! Man am I glad I don't have to machine a custom back plate with a strange slope which at one point I thought might have to happen
Posted: Fri Mar 05, 2021 2:34 am Post subject: |
When you put all that time and effort into something, not sure it will even work, when you finally get to the point where you know it’s actually going to work, is a great feeling..
“It Works!!”
Congratulations _________________ 80 Turbo - Slightly Modified |
Posted: Fri Mar 05, 2021 12:40 pm Post subject: |
Fasteddie313 wrote: | When you put all that time and effort into something, not sure it will even work, when you finally get to the point where you know it’s actually going to work, is a great feeling..
“It Works!!”
Congratulations |
Thanks! I can only imagine what it felt like for you when you got the FrankenCIS up and running _________________ 1980 931 since 1989
Posted: Sat Mar 06, 2021 1:28 am Post subject: |
I'm such a doofis... I just realized the why the housing flat part of curve plane to inner mount flange differs by 2mm. The wheel tip heights differ. The S1 is deeper because the curvature plane is deeper into the housing (the flat part where the curve ends).
Found the m7 left handed nut I needed in one of the two Mellet rebuild kits I have so on to assembly
I'll leave you with this and apologies for the scan powder on the wheel. Too lazy to remove and don't want to loose the balancing 'heavy spot' mark on the wheel. It spins freely even without the o-ring so it isn't centered perfectly
Posted: Fri Mar 19, 2021 1:07 am Post subject: |
Interesting little indicator runnout study. 0.0001" (0.00254mm)
Old used/worn bearing (not that old actually but turbo was damaged by debris through the turbine). Something like this can cause unstable operation no matter how well it is balanced
https://vimeo.com/525561438
New bearing is so sweet
https://vimeo.com/525561916
Also been noticing the spec for the turbo bearing housing is supposed to be 0.630" with the bearing at 0.629" but my bearings are 0.630 or a bit under and the housings are much larger 0.6315 to 0.6325+ inches.
Contemplated making my own bearings until I pulled my third housing and it fell closer to 0.631" It was older and untouched. I have never been a fan of sand blasting because of what it does to toleranced surfaces. Between that and bearings spinning in housings I am sure they loosened up over time... beware
Posted: Fri Apr 02, 2021 12:48 am Post subject: |
360 thrust washer. Fully rebuilt and being assembled. Everything new including turbine/shaft which has the left handed 7mm nut. Self tightens which is cool. Housing selected from a small pile to get best bearing housings. Destined for CS. Will move to that thread with this
Posted: Fri Apr 09, 2021 12:11 am Post subject: |
Bypass Valve Gasket
Blow Off Gasket
Turbo Re-circulation Gasket
Whatever someone might search for it as....
Need two per turbo
930 110 149 00
Sometimes called 'Air Box Gasket' is 930 parlance. Sign of it going bad is a Clickity Clack sound
In my case simply rebuilding. Good simple while I am here anyway
Also, piston can wear in some poorly treated cars. _________________ 1980 931 since 1989
