How to Install a Rear Sway Bar on a 924 without one
Goto page Previous  1, 2, 3, 4, 5
PostPosted: Wed Mar 18, 2015 4:32 pm    Post subject: Reply with quote
Wow !
You should not modify this car. Sell it to someone that wants to keep it original and get a later model.
chris79
PostPosted: Wed Mar 18, 2015 8:21 pm    Post subject: Reply with quote
Why ? I read that sway bar was optional in 924 na before '78
chris79
PostPosted: Wed Mar 18, 2015 10:18 pm    Post subject: Reply with quote
Can anyone post some photos of bottom 924 na ?
PostPosted: Wed Mar 18, 2015 10:21 pm    Post subject: Reply with quote
you should make a new topic for your car, moderator should move all these posts to your topic...we are polluting a how-to topic.
chris79
PostPosted: Wed Mar 18, 2015 11:10 pm    Post subject: Reply with quote
if I create a new post they tell me read how to, I'll have to write somewhere ?
Chrenan
PostPosted: Wed Jun 10, 2015 6:20 am    Post subject: Reply with quote
I'm disgusted to have come back and seen the mess made of my how-to thread. This is how content contributed by senior members is treated? I demand retribution.
Brockoli
PostPosted: Wed Jun 10, 2015 6:50 am    Post subject: Reply with quote
Rare Chrenan sighting!!!! O no, I'm also polluting the thread
XLR8
PostPosted: Sat Mar 10, 2018 8:17 am    Post subject: Finally put a rear sway on my '82 NA. Reply with quote
I found a pair of used 944 S2 Sways (27mm front, 18mm rear) and have only managed to get the 18mm rear bolted in so far.
The car has a 21mm front installed from factory (and for the moment, still does).
She's gone from understeering on power in tight turns to quite dramatic oversteer (tight and medium turns) - even with <125bhp! She would be a handful in the wet!
I plan to install the 27mm front, which I think will even things out a bit. My seat of the pants thinks that a 16mm rear would be an excellent match for the standard 21mm front.
'81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100
XLR8
PostPosted: Wed Apr 11, 2018 8:14 pm    Post subject: Reply with quote
Finally got the 27mm sway bar on the front (18mm already installed in the rear). I installed some Poly main bushings at the same time.
What a transformation! Steering is quicker, muuuuuch flatter cornering, and cornering potential is way faster. Highly recommended.
'81 Porsche 924 NA
Juho
PostPosted: Wed Mar 31, 2021 3:08 am    Post subject: Reply with quote
So i tried installing rear sway bar on my car today, i tried to install in it the hole which you can see but the bolt and dog bone hits the suspension so it cant be installed it, i think im trying to install it in wrong hole which hole it should go?
PostPosted: Wed Mar 31, 2021 3:58 am    Post subject: Reply with quote
You're missing the special camber eccentric bolt with sway bar mount (477 511 516):
  • Shaggy (1980 931) - SOLD (unlucky, but tried hard )
Juho
PostPosted: Wed Mar 31, 2021 4:06 am    Post subject: Reply with quote
i bought that but where should i install it
PostPosted: Wed Mar 31, 2021 5:06 am    Post subject: Reply with quote
It replaces the camber eccentric bolt that is dead center in your picture. While you're at it, those hard fuel lines need refinishing before it's too late.
Page 5 of 5
