No fuel through injectors
kghaas
PostPosted: Sun Mar 21, 2021 5:26 am    Post subject: No fuel through injectors Reply with quote
Its been a while since I was on here last. Bought a 996tt which has taken the attention, but now I want the 931 up and running.
Been 5 years since it last was on the road.
I now have a fuel issue and hopefully some of you can give me som quick pointers to information or further action. I have read the resurection thread and followed the fuel part.
Car gets fuel to the distributor and it feels like high pressure when I press the fuel feed line. I have not measured it.
When I take the injector out, fuel pump on and press the air meter plate; No fuel.
When I take the injector of, and just have the injector line, fuel comes through but not at any significant pressure.
What should I do next? (I will measure fuel pressure going to fuel distributor, but I am quite sure it is in the 5-6bar range.)
Knut
931 RMCH
PostPosted: Sun Mar 21, 2021 5:44 am    Post subject: Reply with quote
Varnished internals in the fuel distributor?
  • Shaggy (1980 931) - SOLD (unlucky, but tried hard )
anthonimartini
PostPosted: Sun Mar 21, 2021 7:27 am    Post subject: Reply with quote
remove the system pressure relief valve and check the the small o ring on the end of the piston/ spring stack has not failed. when it fails you lose most of the system pressure and likely wont have enough to see fuel flow from the injectors. you also will have very low control pressure so the plunger will lift very easily. hope this is the case as its super easy to remedy.
saving a 1977 martini ... please help! (done)
87 924S GF's Daily
77 924 Safari (931 swap) daily
79 MochaSchwartz work in progress
formerly known as turbellion, lost password.
MOTANUL
PostPosted: Mon Mar 22, 2021 3:10 am    Post subject: Reply with quote
In most cases it is the electric fuel pump. Even if it is not completely blocked, it can put less pressure than it would be necessary.
Better check the pressure first.
I have 2 old pumps that work but don't have enough pressure.
When new the pump should go 7-8 bar.
1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979
PostPosted: Mon Mar 22, 2021 9:37 am    Post subject: Reply with quote
+1 .... I second this
Just saw Dan's 941 recently have a plugged up fuel pump line
MikeDanger
PostPosted: Tue Mar 23, 2021 6:19 am    Post subject: Reply with quote
First dump a gallon of acetone into the tank (this is what most "cleaners are made of, and its much cheaper, Brake cleaner is basically aerosol acetone)
and a bottle of Marvel mystery oil (or 1/2L of ATF)
Install an inline gauge from CIS to WUR (you can make your own homemade set up for a lot less, then a prebuilt, and then install it however you want)
id say let the pump run for enough to cycle the stuff through the system and let sit, then check the next day and see if anything starts flowing.
PostPosted: Tue Mar 23, 2021 8:18 am    Post subject: Reply with quote
I would be extremely cautious with the acetone/ATF mixture. It will penetrate in places you didn't think possible (for example, crimped together fuel pump, crush washers, etc).
I put some in an oil squirt can one time and it leaked out the seams overnight. . .after that I only stored it in glass.
MikeDanger
PostPosted: Tue Mar 23, 2021 8:26 am    Post subject: Reply with quote
Im assuming he still has gas in the tank
