DZGunner
Joined: 18 Nov 2014 Posts: 180 Location: Great white north
Posted: Tue Mar 16, 2021 4:20 am Post subject: |
I can't tell but is that a channel on the flat part to relieve the oil pressure to its drain or no? When I did my EFI conversion I just plugged my distributor housing, but also plugged the drain, not knowing it was a drain. Basically kept getting leaks constantly until I unplugged the drain hole. Wondering if you have provisions for that drain, and if not, if you have oil leaking issues.
Also, what you might charge to make one if you were feeling generous
Mike9311 wrote: | The backside of the cover. This setup is actually much lighter than the stock distributor holder. Like I said before the weight will come off from all over.
_________________ 1979 924 (Daily driver EFI)
1979 924 Sebring
1977 924
1977 924 (Parts) |
