ted von Kampen
Joined: 14 Oct 2016 Posts: 154 Location: Scottsbluff, Nebraska
Posted: Wed Mar 03, 2021 2:44 am Post subject: 1981 2.0NA distributor mechanical advance |
I wrote previously about trying to find one of my missing springs. From an article I read it seems that often to change the mechanical advance curve a different spring is used for each of the two spring mounts. This make a dog leg in the mechanical advance curve. Upon checking the Haynes manual I did find that it has two doglegs so the use of different springs might be correct. Has someone opened their distributor to see the springs and are they different?
Some of the speed equipment vendors sell spring and weight kits for chevy, ford,etc so that you can change the mechanical advance curve. Does anyone know who (if anyone) might sell something similar for Porsche?
Thanks for any help possible. ...Ted |
Posted: Wed Mar 03, 2021 6:44 am Post subject: |
This guy will recurve it however you want:
https://supertecperformance.com/
As will this guy:
http://www.vintagewerks.com/ _________________ Toofah King Bad
- WeiBe (1987 924S) - 931 S3
- Red (1987 924S) - Pro44/Spec944
- Shaggy (1980 931) - SOLD (unlucky, but tried hard
ted von Kampen
Posted: Wed Mar 03, 2021 3:35 pm Post subject: Distributor references. |
Thanks guys... I will contact them.
Ted |
