mistert1996
Posted: Mon Feb 22, 2021 8:58 am Post subject: 1980 924 2.0 n/a hydraulic clutch upgrade |
so im after some information if anyone has done it before and how?
prity much im putting a diffrent engine in and need a hydraulic clutch.
as far as i can see the firewall is slightly diffrent to the 944 with a stock hydraulic clutch so i dont know if i can just make one fit? |
Posted: Mon Feb 22, 2021 7:17 pm Post subject: |
Firewall is identical.
Even the indents where you need to drill the holes are there.
The firewall is pretty weak in that area though, so you may want to look into bracing it or reinforcing it somehow.
I didnt when i converted my NA to turbo hydraulic clutch and the firewall was flexible, affecting the pedal feel...and eventually cracking. I then had to reinforce the whole area. _________________ SUPERCHARGED Ruby-sh 924 |
Joined: 08 Jun 2010 Posts: 994 Location: Maysville, Colorado
Posted: Tue Feb 23, 2021 12:10 am Post subject: |
Look up only944.com, you'll see what a firewall brace would look like. _________________ Mike
'77 924
cricketdesigns.com |
Posted: Tue Feb 23, 2021 1:22 am Post subject: |
Turbo pedal assembly might be different...check PET _________________ Toofah King Bad
- WeiBe (1987 924S) - 931 S3
- Red (1987 924S) - Pro44/Spec944
Posted: Tue Feb 23, 2021 1:36 am Post subject: |
Rasta Monsta wrote: | Turbo pedal assembly might be different...check PET |
It is, you need the complete 944/931 clutch pedal assy as well as the master/slave cyl....also you need the 931 bellhousing and probably the clutch as well.
944 pedal shape is also different from the 931.
Good luck. _________________ SUPERCHARGED Ruby-sh 924 |
mistert1996
Posted: Tue Feb 23, 2021 8:00 am Post subject: |
do you have any pic of yours as my firewall looks different from what ive seen
i would put a pic of mine but i dont now how
edit i should have said it is rhd |
Posted: Tue Feb 23, 2021 4:35 pm Post subject: |
Ah, haha well then you need more stuff.
The master cyl is located on the LHD side like on the LHD cars, you just get a long connecting rod that is linking the rhd pedal assy with the lhd master cyl.
Its how the factory did it. Have a loot in PET.
I’ll try to find some pictures later but open the porsche parts catalogue and you’ll see there exactly what parts you need. _________________ SUPERCHARGED Ruby-sh 924 |
Joined: 10 Dec 2006 Posts: 827 Location: Noosa Heads QLD Australia
Posted: Wed Feb 24, 2021 12:26 am Post subject: |
Morghen....that's for the brakes.
Clutch master on RHD cars is on the RHS. Pedal acts on master cylinder through the firewall, with the fluid reservoir sitting higher attached via a flexi hose to the master cyl. Fluid from the master travels via a hard line to the slave cylinder mounted high up on the left side of the bellhousing above the starter motor. _________________ 80/81 932/8 ROW |
Posted: Wed Feb 24, 2021 1:26 am Post subject: |
peterld wrote: | Morghen....that's for the brakes.
Clutch master on RHD cars is on the RHS. Pedal acts on master cylinder through the firewall, with the fluid reservoir sitting higher attached via a flexi hose to the master cyl. Fluid from the master travels via a hard line to the slave cylinder mounted high up on the left side of the bellhousing above the starter motor. |
Ah crap, it was too early for me in the morning, sorry.  _________________ SUPERCHARGED Ruby-sh 924 |
Posted: Wed Feb 24, 2021 2:23 am Post subject: |
And it's way too late for me at night! _________________ 80/81 932/8 ROW |
mistert1996
Posted: Sun Feb 28, 2021 10:42 pm Post subject: |
so this should be some links so you can see what i am working with
[img]https://lh3.googleusercontent.com/RgYfeNAxLJi4PvM384SjFbni9j08Kd0kz-qW5XAspgzL5_iKzVnd6PDvoqYqr_Zmctjg3JDF3SsvFaodEThRuUjNpP1qBgvA3XpZn6yFfptzEz3ZS0KgK9a8-P0zEfY3qrekZkwUOgS3SuXndx0qa2mW5cimU6B2pjE9hklikB8MSh9mNWtxXrej_eowREC9HdpXF-566nZQ9_oD0rTyqDCd_fkvT9Fvg5DyYxtTUuFYEfQHvSSB9xZOD69m4DXuvN02Vh73YZCait2AB_byokibl7b9--8jyfv3YIw4jrq2pbPVOSQ-XjPewnsEx9b3QbmAjYyL3zEd5X_99nwFBhQkaQ0kUWEA-T6jA9EemAzETRLUFXbh6Fyjz_ixIXDtu1DIdm6mxSAZ3zPVPX_kpKPzc5O3USWpafnXanZ4nph5LlM2DAFm_Nn480WuMMDOLgeYvsVbVkcFKogy8l3i2k7nt7Ckwob4Omk_mg8HsetzsRo2MX9BIC-RKsk4EWCGOnVfZ8coEH8KFpNf5Uv9Aa4IdXbBJwOOE-3S5YJ8oXfqktRmUyUTHaQDfnfuFIOxCjt-Xz4_IhphnyiXCo1zd2-mkH1AV26HLrqmAzQDUp1dfk-dAK3SGje26n4GsRtFEwAfO9PT3BznVB7XjF0mD9WLOnBfkz-PwdW1GdSa-bUaoU4hr0vPRqj7r7XzLg=w640-h480-no?authuser=0
[/img]https://lh3.googleusercontent.com/O3ZrOQBmaHtxUVAt-b1WRj47S0_NpsKr6C1bwxkKmrxOwALz2mOC8Q4Nw2120UC2Bqsai6PFbQ_0uPjFr4V4MeHnbe5su3ccA_oV9cP2rQxJ13QwTrfzP4SHIdIHNFFmj3qyYU-r3dllUNEkTXLqDAE-mZDj9bJx1mtgCR0DNThlyUsXfzN1_nGwD9GFBiHSsvgcWhLqSsh7-dyi2Qx34zHOWPEToyRiyHTveVWUeZQxAQ_IWX_NAxB6TqRp7fAUar1g4KAixnX1i5ljYtXpLx3w3bHH71gsIjPClnuvVCilaltAd1DPiZOBnDoup8BV-fQRwtftD5YmsnT7pmJSkE-O1rHlCQnQ40BggWfQ2GUwAKFfJaQyS5XOguz1X-9AK6zJ_0g0hZn4stZySM7KtNXymUfhC3iFZEBZ-eM_Y8oxXeGGzpdIq4ZhjHfzYnCU2MYHCb8NEiUwnj4Y4VhjzPtDi9fxSk1FdBdFRgpC8y25hiNKY11i2ZCtBmz1MA-9bubJvcl45NTgl6k3Q3C5spTdbsbPsCKZ_aeGbbnMLEEV530qQFvLicboIffmIaV3z4aGAwjtyHPUWTd2tuAW1GsKcYdY3U0kkT62e0neEcI_ngUOcErGR7LEHGiakJeBtpt1qR_A1mlZ0-UwKIb1ue9xzc4TNUl_CtB6jH4d307l6lk-mc2i-AQtWcfkXg=w640-h480-no?authuser=0 |
Posted: Mon Mar 01, 2021 2:12 am Post subject: |
