WildP1
Posted: Sun Feb 21, 2021 11:31 am Post subject: 1976 924 Idle gets rough after a short time |
Hello all,
My 1976 NA 2.0 924 has a rough idle. Compression is good. After I found and fixed a bad vacuum leak it ran okay in all RPM, though the idle was never below 1000RPM and when adjusting the air/fuel mixture screw it didn't run as smoothly at 800-900RPM. After standing for a week the cold starts were still quite good but after a minute or so it gets really rough but throttle repsonse isn't suspiciously bad. The idle on a warm-ish engine is bad straight away.
I bought it after it has been standing for at least a year with a disassembled engine.
Link to a short clip of it after a cold start: https://youtu.be/L_iCS8Nj_1w
Any suggestions on what it could be?
Thank you very much in advance!
Cheers. |
Harm
Posted: Sun Feb 28, 2021 1:13 am Post subject: Re: 1976 924 Idle gets rough after a short time |
Please do post in General Discussions.
First question:
— The OLDer engines use old fashioned Spark Distribution by 'Points'. Did you look into the Spark Distributor's housing and measure/set gap?
Then
— See if enough fuel is able to reach the Fuel distributor (probably is, since it clearly starts running by the Cold Start Valve and/or WUR).
— Check if every single injector gives an even amount of fuel in a good cone. Hot start problems will happen when injectors don't hold pressure and leak after shutdown.
— Did you use a timing light and check the dot on the back of the cam wheel? There is a difference between front and rear dot. Use the right one: check TDC.
Document/fotograph your current setup of fuel/timing/mixture before you take it all over the place .
When running almost perfect: Check AFR and CO2 for verification exhaust fumes are in spec and the engine isn't running to lean (and burning your rings). |
WildP1
Posted: Mon Mar 01, 2021 6:23 pm Post subject: |
Thank you for the reply! Will put it in general discussion next time.
The timing and the distributor gap should be set correctly. I double
checked the timing with a timing gun too.
I will check the fuel flow to the distributor and also check the injectors. Shall I crank the engine when I've pulled out all injectors and see what the spray pattern/ amount of fuel coming out looks like?
I took it for a drive (about 50km) and it idles better now but doesn't idle nicely below 1000rpm. I think I will have to drive it more and it might clear up a bit. I think the mass air flow sensor might be stuck a little and it could get better if I drive it for a while. Under full throttle it runs really smoothly but at like 3-4k rpm it stutters a bit.
Thanks. |
anthonimartini
Joined: 17 Feb 2020 Posts: 240 Location: portland oregon
Posted: Sun Mar 21, 2021 7:35 am Post subject: |
your warm up regulator is out of spec causing lean running on a warm engine. you need a fuel gauge set to check and remedy. you may need to find a good one or try to rebuild yours. _________________ ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password. |
WildP1
Posted: Sun Mar 21, 2021 11:48 pm Post subject: |
Thanks a lot for the advice, will definitely take a closer look at the WUR. |
