Posted: Tue Dec 22, 2020 8:41 am Post subject: |
It was a loose, spur of the moment, style of test on a warmer day and oh so long ago.. as in last century long ago _________________ 1980 931 since 1989
Posted: Tue Dec 22, 2020 10:34 am Post subject: |
I like the lag.. It makes the “drivability” fun, and keeps me on my toes..
You feel the 2670 lag is much more Cedric? Makes me wonder what a k27 would feel like.. _________________ 80 Turbo - Slightly Modified |
Posted: Tue Dec 22, 2020 4:28 pm Post subject: |
| Fasteddie313 wrote: | I like the lag.. It makes the “drivability” fun, and keeps me on my toes..
You feel the 2670 lag is much more Cedric? Makes me wonder what a k27 would feel like.. |
Small lag differences between the K26 2660 6.10 and the K27 3257 6.10 on my car. Bigger wheel takes a little more time to spool. Biggest difference is the K27 has top end legs. Big legs. When it comes on boost, its strong all the way up to top end in big gears on the highway. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Tue Dec 22, 2020 5:56 pm Post subject: |
Quite hard to compare since I had the intercooler added at the same time. But in the logs it builds boost earlier now than it did before, and its very responsive when going on and of the throttle, which is something i like for hard driving. _________________ 1980 924 Turbo
chuck21401
Joined: 20 Feb 2005 Posts: 608 Location: Annapolis, MD
Posted: Fri Dec 25, 2020 4:32 am Post subject: |
I replaced the thermostat and installed a low temperature fan switch.
The car is running cool again. This pic was taken after a 30 min ride with a number of boost runs.
The nice thing about the 924 turbo is that you have to move at least three other parts to accomplish any task. To remove and replace the fan switch, I had to remove the air box and put the headlights in the up position.
Based on Dan's advice in this thread, I went with a 82C thermostat and 75C fan switch. http://www.924board.org/viewtopic.php?t=41044
The fans have yet to come on. The radiator is warm but apparently not hot enough to kick on the fans. Air temps last night were around 30F degrees and today it's around 50F _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler
chuck21401
Posted: Fri Dec 25, 2020 4:43 am Post subject: |
| Mike9311 wrote: |
When you hop out of the car, pop the hood and put your hand on the exhaust side of the intercooler and then the throttle body side. You should notice a big difference. |
Here are some pictures after 30 minute runs. Last night the air temp was around 30F. Today the air temp is around 50F.
Last night
This morning
 _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
chuck21401
Posted: Fri Dec 25, 2020 5:10 am Post subject: |
The air temp sensor I bought isn't going to fit.
I had hoped to connect it to the 1/8 NPT 27 port which is meant for water/methanol injection.
But it turns out the sensor probe is a big thing...other hoses and a hard pipe are in the way. I disconnected the hose pictured below in an attempt to do a test fit. No joy.
Here's my question...if I connect the sensor to the overboost port (switch is currently not connected; the wire is grounded to the block)...would that give me an accurate reading? I just need an adapter to go from 1/8NPT to M12 1.5.
Another idea would be to tap into the stock S2 temp sensor (93160612300) which is not connected. Anyone know the threads on the stock sensor? Apparently those are NLA...I figure I could sell that one (assuming that it works...would need to figure out how to test it) and connect the new probe there?
GregSC
Posted: Mon Jan 11, 2021 5:21 am Post subject: |
Hey Chuck,
I can confirm that a M14x1.5 plug fits into the space vacated by the stock intake air temperature sensor. Also some of the factory literature I have mentions that as the appropriate size. _________________ 1981 931 |
chuck21401
Posted: Wed Jan 13, 2021 3:44 am Post subject: |
| GregSC wrote: | Hey Chuck,
I can confirm that a M14x1.5 plug fits into the space vacated by the stock intake air temperature sensor. Also some of the factory literature I have mentions that as the appropriate size. | .
Thanks, good to know. I bought two adapters... M14 x 1.5 Male to 1/8-27 NPT Female and M12 X 1.5 Male to 1/8-27 NPT Female...depending on where I decide to mount the sensor. I'm also trying to figure out where to mount the gauge in the cockpit. I'm leaning towards fabricating a bracket to mount it on the tray below the glovebox on the passenger side.
In other news I cleaned up the wiring for the intercooler pump and heat exchanger fan. Both are controlled by a dash mounted switch. I ran a separate wiring harness with a relay and fuse.
My dashboard is already cracked so I figured one more hole would not make a difference.
Posted: Fri Jan 15, 2021 12:12 am Post subject: |
Nice, I like it! I also like the idea of being able to turn it off for starting. The CS is always on but the silver '82 is by switch. They both need some wiring TLC _________________ 1980 931 since 1989
chuck21401
Posted: Mon Jan 18, 2021 7:57 am Post subject: |
| chuck21401 wrote: |
I ordered the intake temperature gauge... |
On hindsight, a flush mount gauge wasn't the best idea...I'm having trouble figuring our where to put it.
So for now I'm going to have a custom aluminum panel made and see how it looks. I read about this website https://www.frontpanelexpress.com/ on a thread on RENNLIST here https://rennlist.com/forums/944-turbo-and-turbo-s-forum/655024-custom-under-radio-gauge-panel-pics.html .
If it looks too home grown I'll have to think about something different.
I suppose I could delete the radio and replace it with a panel holding the MBC and the intake air temp gauge. But I don't want to lose my radio yet.
So this panel will be attached to a bracket on the right side of the center console. With any luck, it should look something like this (the grey circles are M3 studs on the back of the panel):
I'm going to switch the setting on the gauge to the Fahrenheit scale. The colonies have yet to fully embrace the metric system.
The Front Panel Express website has software to design and then preview the panel.
chuck21401
Posted: Tue Jan 19, 2021 11:12 am Post subject: |
That temp sensor looks more like an EGT than something you would want to use as an IAT.. _________________ 80 Turbo - Slightly Modified |
Posted: Tue Jan 19, 2021 6:26 pm Post subject: |
Looks like bolt on thermocouple?
I used two of those bolted my head. Never gave temp readings I was expecting. Also relatively slow to react to temp changes compared to the IAT sensors I have installed pre and post IC. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
chuck21401
