1 stud build
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Juho
PostPosted: Tue Jan 12, 2021 7:56 pm    Post subject: Reply with quote
You think gazs would be a good upgrade compared to ta technix coilovers front and bilstein strut in back, just thinking of it because gazs would be easier to get pass inspection
Juho
PostPosted: Tue Jan 12, 2021 10:13 pm    Post subject: Reply with quote
does anyone have tuv papers for bilstein b36-016?
safe
PostPosted: Tue Jan 12, 2021 10:28 pm    Post subject: Reply with quote
Is TUV relevant to Finland?
Aren't you allowed to change suspension?
/Magnus, Stockholm Sweden
Porsche 924 -79 NA, under EFI and turbo conversion
Do you actually have such absurd laws there that you have to use the same make of shocks?
Juho
PostPosted: Tue Jan 12, 2021 10:32 pm    Post subject: Reply with quote
you need some kind of papers here to register the car with new suspension components
Juho
PostPosted: Mon Feb 01, 2021 4:12 am    Post subject: Reply with quote
Bought 944 s front swaybar but the side mounting is different what should i do? use the side mountings from the old sway bar or what?
safe
PostPosted: Mon Feb 01, 2021 4:59 am    Post subject: Reply with quote
The 944 uses a different mount both to the suspension arms and to the body.
Check the PET for exploded view pictures/drawings and part numbers.
PostPosted: Mon Feb 01, 2021 5:22 am    Post subject: Reply with quote
Look thru the "How to" section. Years ago I did a how to on it. It requires changing to the 944 steel control arm, they are inexpensive over here, about $25.
Mike
'77 924
cricketdesigns.com
Juho
PostPosted: Mon Feb 01, 2021 5:57 am    Post subject: Reply with quote
Thank you, what about the rear swaybear will it bolt on?
PostPosted: Tue Feb 02, 2021 12:15 am    Post subject: Reply with quote
If it has the brackets welded to the TB carrier it will bolt on. New bushings probably required. I had to make new mounting plates for the front and it was a photobucket picture which may not show up. If you need it I could email it to you.
Mike
'77 924
cricketdesigns.com
Juho
PostPosted: Wed Feb 03, 2021 6:08 am    Post subject: Reply with quote
i keep getting same pn for 944 and 924 control arms
PostPosted: Wed Feb 03, 2021 7:21 am    Post subject: Reply with quote
They don't make the 924 control arms with the sway bar mount out front anymore. The 944 arms have the holes in the arm for the 944 sway bar bushing clamp and bushing. Look at a 924S/early 944 parts diagram.
Mike
'77 924
cricketdesigns.com
Juho
PostPosted: Wed Feb 03, 2021 9:00 am    Post subject: Reply with quote
My front sway bar needs a control arm like this
Can i just swap the control arm mount from the 924 sway bar into 944s swaybar?
Harm
PostPosted: Wed Feb 03, 2021 9:22 am    Post subject: Re: 1 stud build Reply with quote
^Those won't fit.
You need the common VW Golf Mk1 part (McPherson suspension)
Make sure it includes holes to connect the sway bar.
The other parts you'll need shown hereā€¦
Juho
PostPosted: Wed Feb 03, 2021 9:27 am    Post subject: Reply with quote
but my 944s sway bar has a different type of mounting to controll arm
Page 6 of 9
