Ohio-924
Posted: Sat Jan 09, 2021 8:02 am Post subject: What's the horsepower difference between US and Euro spec |
I have 1977 924 and I want to bump up the horsepower without having to add forced induction or something along those lines. Something to note as well is that my 924 hasn't ran since 2007 and has ran a total of maybe 5 times and only ran for about 10 or so seconds at a time. I heard there's a difference between a Euro spec 924 and a US spec 924, is there? |
Posted: Sat Jan 09, 2021 11:02 am Post subject: |
Yes
Euro 924, 125hp
US 77 924, 95hp
The main difference are the pistons which result in a different compression ratio. I believe there are other small difference which I can't remember at the moment. _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Joined: 28 Feb 2008 Posts: 1361 Location: Washington DC area
Posted: Sat Jan 09, 2021 11:31 am Post subject: |
There is also a difference in the crankshaft. The early 924s had different sized bearings. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Posted: Sat Jan 09, 2021 12:10 pm Post subject: |
The 77.5 model got bigger intake valves, 40mm vs 38mm, a higher compression ratio from 8.5 vs 8.0 and a slightly different camshaft with more duration. They also changed the torsion bar spring plates from the one piece Super Beetle type to adjustable. They kept that cam for the duration of the model run including the turbo's. They timing was also retarded probably for pollution compliance.
My opinion is that because the airflow in the head basically stalls at .400 lift least expensive way to get more power is to get longer duration cam in the 265-275 range with the normal lift(.470+-) and then advance the timing quite a bit. Track car is 41 degrees at 3000rpm, I going to play with that on my street car in the spring. Idle might suffer a bit. Stock dimension cams are available from Newman Cams, Piper Cams and Kent Cams in the UK and prices are in the $400 range. All the cams in this country are regrinds meaning valve train modifications. I got a semi-race cam from Cat Cams in Netherlands, delivery was in about 4 weeks and the shipping was in 3 days and shipping cost $40. _________________ Mike
'67 MG Midget Dp
Posted: Sun Jan 10, 2021 2:29 am Post subject: |
Mike
Have you tried epoxy in your head testing? I believe you built a flow bench right? Just curious
Mike _________________ 1980 931 since 1989
Posted: Sun Jan 10, 2021 3:20 am Post subject: |
Not too hard to get 145bhp out of a euro NA. The U.K. racers do this off the bat and they have regulation limitations to what they can do to the engine. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Sun Jan 10, 2021 5:46 am Post subject: |
Carrera, I'd like to see what the UK rules are for the 145 hp from an NA engine. Can you direct me to a set of the rules so I can compare to my SCCA rules. I'm getting a bit over 130 hp with the stock cam and compression ratio. I use 41 degrees timing and the engine runs out of torque (not revs) at 6500. _________________ 1979 924 NA race car
Karlio
Posted: Sun Jan 10, 2021 7:20 am Post subject: |
Fifty50Plus wrote: | Carrera, I'd like to see what the UK rules are for the 145 hp from an NA engine. Can you direct me to a set of the rules so I can compare to my SCCA rules. I'm getting a bit over 130 hp with the stock cam and compression ratio. I use 41 degrees timing and the engine runs out of torque (not revs) at 6500. |
Piper cam ultimate(specs on the piper website) , 87.5mm euro pistons, crank scraper, audi 100/golf/neuspeed/924 turbo throttle body, 'modified' wur, k&n panel air filter, a proper stainless exhaust, 99 octane fuel, solid lifters.
No porting,no lightened flywheel. Standard ignition set up, standard fuel dizzy set up. |
Posted: Sun Jan 10, 2021 7:27 am Post subject: |
Ah, thanks. I'm not allowed the Piper cam nor the Neuspeed throttle body. Everything else I've done. I modify the fuel via the frequency valve to produce 12.8 CO (max power on the dyno) on my wideband meter. _________________ 1979 924 NA race car
Karlio
Posted: Sun Jan 10, 2021 7:48 am Post subject: |
Can you deck the block by 1mm and can you cut down the valve guides.? |
Karlio
Posted: Sun Jan 10, 2021 8:10 am Post subject: |
We were limited by regs to143 hp and 1000kg with driver post race. 15 inch wheels, gaz or leda shocks, solid front discs, rear drums.
You can get more hp by advancing the timing but that causes HG issues as you are aware
[/img] |
Posted: Sun Jan 10, 2021 9:09 am Post subject: |
We are limited to 1/2 point increase in compression ratio either with different piston or cutting the block. I went with Diamond pistons to get the compression bump and 1mm increase in piston diameter. I do run it at 41 degrees advanced as that showed optimum power at full chat on the dyno.
The engine is the bad news in my class (oh yes, I have to run stock gearbox ratios) but I'm allowed the 944 brakes; vented rotors front and rear with 15 inch wheels. I've raced 911s, 356s, VWs, BMWs, M-Benzs and an Acura Type R and the 924 is the best neutral handling and stopping car I've ever had. That's the reason I do so well in the class I run (Volvo, BMW, Alfa, VW, Honda, Mazda). But most of them pull me on the straights due to weight and HP. Braking and cornering are the 924 strengths as well as aerodynamics on really long courses. I'm required to weigh 2495 lbs with driver coming in off track while most of my competitors are 100-200 lbs lighter.
PS: stock head, intake runners, valves and guides. No work allowed. _________________ 1979 924 NA race car
Karlio
Posted: Sun Jan 10, 2021 9:16 am Post subject: |
That is one heavy car, proper disadvantage. |
Posted: Sun Jan 10, 2021 7:25 pm Post subject: |
Fifty50Plus wrote: | We are limited to 1/2 point increase in compression ratio either with different piston or cutting the block. I went with Diamond pistons to get the compression bump and 1mm increase in piston diameter. I do run it at 41 degrees advanced as that showed optimum power at full chat on the dyno.
PS: stock head, intake runners, valves and guides. No work allowed. |
Interesting, why are your required weight higher?
Are you allowed any aerodynamic modifications? Like building an undertray, or maybe using the 944 rear hatch/spoiler? It would give you some more top end speed without more hp. _________________ 1980 924 Turbo
Posted: Mon Jan 11, 2021 10:58 am Post subject: |
We are allowed to use the 924 Turbo tail but not the 944 version. I also retained the front engine undertray to aid in cooling but don't think it does much else.
SCCA does not appreciate Porsches winning any races since Porsche does not provide sponsorship to Corporate SCCA HQ unlike Mazda, Nissan, Toyota, BMW, and a few others. In the '80s, I was dominating D-Prod with a 911 at a realistic weight. In 2000, I started building a 2.4 911 based on it finally being approved for Improved Touring at 2200 lbs (factory weight). When the club heard that I was building another Porsche, they changed the rules and added 300 lbs to the minimum weight before I even hit the track. Datsun 240Zs were the dominant car (Nissan giving money to the club office) at 2300 lbs. After I finally got my car built and dialed in, I was 1/2 sec slower than the winning Datsuns. The 300 lbs SCCA gave me made a big difference in my lap times.
So I sold the 911 and built my first 924 after seeing what Vaughan Scott did with his car at Road Atlanta (long track, heavy braking needed). It's a great car but could use a few more horses on the shorter tracks. _________________ 1979 924 NA race car
